Old 04-12-2013, 01:31 AM   #1
Ryeong86
Ryeong86's Avatar
Drives: 2015 Sti Launch Edition
Camber Question
I just got my alignment done on my FR-S and I was told by the tech that I can't do custom adjustments with stock suspension parts. What is needed to adjust my camber? Camber plates, crash bolts? I just need to be put into the right direction.
Ryeong86 is offline   Reply With Quote
Old 04-12-2013, 02:53 AM   #2
eckoflyte
Drives: Toyota 86 GTS
Camber bolts. SPC 81280 is the part number you need for eccentric cam bolts.
You can get crash bolts which are just thinner bolts which give play in the knuckle to allow you to adjust. Subaru make them also. Unsure of part number. If you do a search it's posted somewhere in one of the threads.
eckoflyte is offline   Reply With Quote
Old 04-12-2013, 03:47 AM   #3
donutfilling
donutfilling's Avatar
Drives: frs
Fronts:
Cheapest option would be camber bolts or crash bolts. These give I believe around 1.5 degrees at most. $5-$30
Next option would be different top hats, usually adjustable camber top hats. There are also nonadjustable ones that just give you added camber if you want.
-Usually come with coilovers but top hat prices vary.
Rears:
Whiteline bushing/bolt camber kit. Also around 1.5 degrees of adjustment I believe
~$130
Most adjustable and common option would be adjustable rear lower control arms.
~$400
donutfilling is offline   Reply With Quote
Old 04-12-2013, 04:10 AM   #4
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Rear spc camber arms are under $300 shipped
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-12-2013, 09:06 AM   #5
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
I agree, you cant beat steel
I ordered me some of the racerX stuff, still waiting for it to come in, much beefier than the SPC, if you plan on running r-compounds and such the spc appear a bit under built
I also like the stance arms if you're part of low/slow crowd
Huehuecoyotl is offline   Reply With Quote
Old 04-12-2013, 12:05 PM   #6
Ryeong86
Ryeong86's Avatar
Thanks for the help. I am looking to get some camber for SCCA Solo events when I decide to move from stock class.
Whiteline Camber bolts question (KCA416) ML Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-02-2013 11:25 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
Camber Question subaruatheart Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 03-24-2013 01:49 PM
