Old 04-11-2013, 01:55 PM   #1
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Lightweight Drivetrain Bits Video
Here is a quick video for anyone curious about the effects of a lightweight crank pulley and flywheel on our cars. First segment is stock, second segment adds the GFB pulley set and the final segment is with the pulleys and ACT prolite flywheel + clutch.
Thanks to @Circuit Motorsports for the parts!
[ame]http://youtu.be/hE2tQPCTewg[/ame]
The already awesome throttle response is much better now. The acceleration in 1st and 2nd as the car ramps up feels brutal. Rev matching feels far more sporty now. When the car was stock, it felt like a pretty lazy experience since the car revved up and down so slow. The ACT stage 1 clutch and prolite flywheel is very streetable. It's worth noting that I took the flywheel and clutch cover to a professional balance shop to be balanced as an assembly and they only had to make minor adjustments. It takes a little getting used to but I can launch nice and smooth without issues now. There is a small increase in NVH at certain rpms and while the clutch is pressed in. It's mostly sports car sounds though so I like it. More cues on what the car is doing.
I have to say, after stripping out ~150 pounds (35 rotating), the car feels pretty damn fun. Now to start adding powah!
industrial is offline   Reply With Quote
Old 04-11-2013, 02:54 PM   #2
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Not sure if it's because I don't have sound at work, but it didn't seem all that much different. lol
shu5892001 is offline   Reply With Quote
Old 04-11-2013, 04:42 PM   #3
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
I can't tell if the revs went up any faster but what I can tell is the REVs dropped faster so it's definitely doing something !
AJ PwR is offline   Reply With Quote
Old 04-11-2013, 06:23 PM   #4
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
slight change in speed, but this is not underload -- so I'm not sure how much you'll actually gain from this. As the previous poster said, drops rpm a lot faster!
CamryDS is offline   Reply With Quote
Old 04-11-2013, 06:38 PM   #5
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
There was almost no difference with a pulley alone. With the flywheel there is a pretty huge difference up and down. The car revs up pretty fast stock but has some serious rev hang so its probably easier to notice the difference revving down. The car revs up much faster too, not sure how to quantify that though.
Old 04-11-2013, 08:55 PM   #6
cfusionpm
Drives: Firestorm 6MT Scion FR-S
Would like to see a video under load. A road acceleration difference.
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 04-11-2013, 09:30 PM   #7
s2d4
s2d4's Avatar
hmmm, have you checked out the AVO DBW throttle controller?
You can lighten the pulleys/flywheel all you want but if you are limited to how the drive by wire throttle is applied, it'll just be controlled to decelerate really quickly...
Old 04-12-2013, 02:01 AM   #8
evilconcarne999
My LFA
evilconcarne999's Avatar
Drives: No Boost
i have all the pulleys replaced that you can currently replace, along with a lightweight ACT clutch/flywheel, drive shaft, and a bunch of other parts and i deffinitely notice a difference from what it was before. Its not like FI crazy difference but it is very noticeable and with a short throw and bushings in the transmission makes the car way more nicer/enjoyable to drive as a daily driver and on the track.
WSIR 1:46.023 (Need Better Tires)
My Car Build: 171.9WHP/137WTQ (Mustang Dyno)
http://www.ft86club.com/forums/showthread.php?t=21824
My For Sale Aftermarket and OEM parts
http://www.ft86club.com/forums/showt...484#post998484
evilconcarne999 is offline   Reply With Quote
Old 04-12-2013, 02:45 AM   #9
wootwoot
Drives: FRS
To the OP: I can see the difference but I can HEAR the difference even more. I bet that thing is a blast! Thanks for sharing.
Wow... That is a lot of weight you took of that drive train! Do you have any issues with idle or CEL's? I am wanting to go that route but am afraid of running into issues.
wootwoot is offline   Reply With Quote
Old 04-12-2013, 02:53 AM   #10
g0lden
Drives: 2013 Scion FR-S Argento
After I get the exhaust and suspension work done I would like to upgrade the clutch flywheel setup.
I can't say much for this car, but my 97 Integra had a ACT clutch and lightened flywheel, and damn that car felt great compared to others i've driven.
g0lden is offline   Reply With Quote
Old 04-12-2013, 08:35 AM   #11
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
Great, thanks a bunch, NOW I need a light weight flywheel TOO. *grumble grumble*
Mobius357 is offline   Reply With Quote
Old 04-12-2013, 08:39 AM   #12
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
These would be great mods for people that like to rev their engine while sitting still!!
SloS14 is offline   Reply With Quote
Old 04-12-2013, 09:03 AM   #13
jwjknorr
Drives: FRS 2013
Ohh the jokes. From experince, the revs are always hard to tell on lightweight flywheels when sitting still. Its the feel and freedom while driving that is noticeable.
jwjknorr is offline   Reply With Quote
Old 04-12-2013, 04:13 PM   #14
Red2Liter
Drives: Subaru BRZ Limited, Red
Lightening Flywheels
The mechanical Gods giveth and taketh away! If you're aiming to increase HP and it ends up being mostly at high RPM's, then a low inertia flywheel should get you to the power curve of a modified engine faster and you'll end up doing a lot of shifting to keep the engine on peak. If you're looking for torque and acceleration, the heavier flywheel will maintain momentum and the heavier flywheel will conserve the energy with it's spinning mass once you've spun it up to speed. It will just take a bit longer to spin up to speed. It's a balancing act to achieve the best drivability result.
Red2Liter is offline   Reply With Quote
Go Fast Bits - Photos of the pulleys that shed weight for 2013 FT-86 SpeedFactory Engine, Exhaust, Transmission 34 10-20-2016 12:14 PM
BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" GuerillaRacing Wheels and Tires 116 01-20-2015 06:32 PM
Go Fast Bits Lightweight Pulley Kit on sale & Free Shipping @ Circuit Motorsports Circuit Motorsports Engine, Exhaust, Bolt-Ons 58 03-20-2013 02:07 PM
Agency Power vs. Perrin Lightweight Pulley - Review Video FT-86 SpeedFactory Engine, Exhaust, Transmission 5 10-04-2012 03:07 PM
Anybody fitted any STI bits yet ICantAffordAnLFA BRZ First-Gen (2012+) — General Topics 4 07-12-2012 07:59 PM
