Old 08-24-2012, 08:48 PM   #1
Illusive
Drives: 2005 Subaru STi
extended DDPR stock FR-S Dyno testing
I figure I'll just post up the plots and then discuss them afterwards.
Here is the extended testing (250 miles to 8500 miles with 2 oil changes) with an ECU reset for curiosity's sake tossed in.
Here's just the ECU reset before/after:
All runs in 5th gear, on the same dyno (ours) and the same car obviously.
Runfile 10 represents the best pull on a fresh motor with 250 miles on the odo.
Runfile 17 represents the best pull on a broken in motor with 2500 miles on the odo and a fresh oil change
Runfile 21 & 22 were done today back to back at 8500 miles with no changes but fresh oil from runfile 17. It represents additional power from break-in at the 8500 mile mark
Runfile 23 represents a fresh ECU reset pull with ideal conditions (cold coolant, warm oil)
Runfile 24,25,26 represent a hot motor and were done with zero cooldown between pulls.
The second plot is just to give a good example of what a fresh ECU reset can do to the power plot.
We previously argued that the ECU is more like a toyota ECU in that it runs max timing on reset and slowly pulls back timing as knock is detected. Other's had made the claim that it is more like a subaru ECU in that it runs a dynamic advance multiplier below max and slowly adds timing back in.
With this dyno testing we can confidently say that the ECU runs max timing on the ECU rest.
Furthermore we can give advice for those seeking to have parts installed on their vehicle, and or tuning.
Based on our extended testing, we recommend not having the vehicle tuned until at least 2500 miles on the odo (and hard driving after the first 500 break-in miles.)
We also recommend, prior to dyno testing/tuning, to reset the ecu get a baseline pull or 3, install parts, reset the ecu again and do the final after dyno.
Doing it in this way will eliminate any power gains from an ecu reset and show just what the parts will make.
Not doing it in this way enables others to potentially inflate their power claims.
Illusive is offline   Reply With Quote
Old 08-24-2012, 08:57 PM   #2
2forme
Thanks Illusive. This gives me a proper procedure when dynoing parts myself!
Old 08-24-2012, 09:47 PM   #3
SpeedR
First86 / boat thief
Drives: MKIV Supra
Good info thanks for doing this for the community.
SpeedR is offline   Reply With Quote
Old 08-25-2012, 11:24 AM   #4
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Yeah - we were very pleasantly surprised to see break in still continuing to deliver HP gains at 8K miles. The 178 HP dyno also made us think that race gas may well be worthwhile on the stock ecu.
Boosted2.0 is offline   Reply With Quote
Old 08-25-2012, 01:35 PM   #5
xwd
How did you do the ECU reset just pull the negative battery cable and press he brake? That's how I always did it on my older Subarus.
Old 08-26-2012, 10:20 AM   #6
Illusive
If you dont have a toyota techstream lic, then pulling the negative battery terminal is the easiest way to reset the ECU
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
FR-S Dyno testing at DD Performance Research inc. 2ZZ comparison Boosted2.0 Engine, Exhaust, Transmission 120 04-07-2013 10:46 PM
Mach V's Dyno Testing tjoy Engine, Exhaust, Transmission 20 08-06-2012 10:52 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 08:55 AM
