Old 04-04-2013, 09:25 PM   #1
nbafandan
Phantom
Drives: Whiteout MT
Custom Box Plans
I asked one of my Construction teachers if he can build a custom subwoofer box that fits on the side of your trunk ( like the OEM audio+ thing) and he said he can look into it if I have the plans.....
Im pretty new to this but does anyone have "plans" for their custom box that they can share with me?
Thanks!
nbafandan is offline   Reply With Quote
Old 04-04-2013, 09:34 PM   #2
cruzinbill
Drives: Argento 6spd FR-S
No, they aren't gonna share their build plans for that exact reason
cruzinbill is offline   Reply With Quote
Old 04-04-2013, 10:02 PM   #3
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Most of those are made with molds anyway, not just making a mdf box for sure.
JoeBoxer is offline   Reply With Quote
Old 04-04-2013, 10:18 PM   #4
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Make your own plans. Make a cardboard mockup so you can test fit, and get the shape right, and then use that to build the real thing.
Old 04-04-2013, 10:39 PM   #5
nbafandan
Phantom
Drives: Whiteout MT
I see so its not something you can just make with your construction teacher who has never done anything like this before?
Old 04-04-2013, 10:51 PM   #6
neutron256
neutron256's Avatar
You're going to need to do some research yourself, the teacher isn't going to be able to just show you how to do it, but if you come to the with a good plan they can probably help with the tools/techniques needed.
Edit: And be prepared to fail at first. Learning how to build things like this takes a lot of experimentation. Almost no one gets it right on their first try.
Old 04-08-2013, 03:33 AM   #7
WolfSongX
WolfSongX's Avatar
Drives: 2013 Subaru BRZ Limited SWP
Google "sub woofer box construction" and then be prepared for a lot of reading. A sub box is an acoustical device designed to work with a specific brand and type of speaker, not a simple generic container. Depending on the specs of the subwoofer you are using there is an optimal amount of airspace necessary for the best sound, and an optimal amount of airspace required for the most sound.
If you want bass the easy way, several companies offer pre-loaded enclosures that are matched to a speaker or your local car audio place could recommend a sub and enclosure pairing. If you truely want to learn, then you can learn how to size the enclosure to the sub and then choose whether you buid or buy the correctly sized enclosure.
Derek
2013 BRZ Limited SWP
Professional driver in search of closed course..
WolfSongX is offline   Reply With Quote
Old 04-08-2013, 03:38 AM   #8
ft_sjo
Drives: GT86
What is a 'construction teacher'? Do they build houses? Skyscrapers?
Get someone that knows what they're doing to help you, or just buy one.
Old 04-08-2013, 07:30 AM   #9
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
NO!
chadstyle is offline   Reply With Quote
Old 04-08-2013, 08:09 AM   #10
AtlasMick
Drives: FR-S 2013 Asphalt
You'll find that people aren't likely to be able to "share" their plans with you because if you are making a custom box (I think you mean fiberglass), then you just need to get in there and make it. As you go, you'll want to measure the airspace that will be inside the box to fit your application (ie, the Vb specifically required by your subwoofer). Hope this helps.
Hopefully this will also help. I've measured the airspace within the cavity below the rear quarter window glass. This cavity has approximately 1 ft3, but you can get up to 1.25 ft3 if you move out of it a bit. I haven't measured the boot space within the trunk.
Good luck!
AtlasMick is offline   Reply With Quote
AT owners only, custom CF paddle shifters, pin stripe custom color BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 80 02-03-2016 10:35 AM
FS: Custom Acrylic Accents, $13. YOUR custom design! Cupholder and Mission Tray too! Diode Dynamics Interior Parts (Incl. Lighting) 155 11-19-2014 11:42 AM
What are you plans for you beloved BRZ? VesperLynn BRZ First-Gen (2012+) — General Topics 24 03-11-2013 05:17 PM
Panmans plans for the weekend. Panman AUSTRALIA 13 01-20-2013 12:25 AM
No Plans Tonight? 5hairpins Southwest 12 11-17-2012 07:11 PM
