Old 04-02-2013, 06:01 AM   #1
fiveoneone
Drives: 86 White GTS
Rears not camber adjustable?
So I got an alignment today and was told that they couldn't adjust the rear camber. I've got the car lowered on BC BR coilovers (camber plates at the front but none at the rear). Natural camber for the rear is currently -2 degrees for the left side and -2.5 degrees for the right side.
I want to bring back the right side to -2 degrees to be the same as the left side but I was told that it can't be adjusted and that I would need to replace the stock upper control arm with an adjustable upper control arm to be able to adjust the rear camber.
Can anyone verify that what I have been told is correct? If so, what is a good brand for adjustable upper control arms?
fiveoneone is offline   Reply With Quote
Old 04-02-2013, 06:11 AM   #2
geeang
geeang's Avatar
Drives: Subaru BRZ
The rear camber on the FRS/BRZ/86 is can be adjusted if you have adjustable lower control arms, or you can also get the whiteline camber bushing kit for the rear.
For the adjustable lower arms, common brands are Cusco, SPC, GT Spec, Whiteline, Stance etc.
geeang is offline   Reply With Quote
Old 04-02-2013, 06:29 AM   #3
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Whiteline bushing kit as mentioned by @geeang is good for +/- 0.75 degrees according to the specs and that sounds like what you want. This is their Aussie site http://www.whiteline.com.au/product_..._number=KCA326
There may also be a vendor on here offering a club discount but not sure.
nzer is offline   Reply With Quote
Old 04-02-2013, 06:36 AM   #4
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Whiteline do not yet have rear lca for sale.
Old 04-02-2013, 06:58 AM   #5
robispec
Drives: Black frs project
got the whitline part in stock
robispec is offline   Reply With Quote
Old 04-02-2013, 08:45 AM   #6
d1ck
Drives: Black 2013 FRS
Has anyone successfully corrected this condition (Diff camber on L/R sides) by shifting the rear subframe?
d1ck is offline   Reply With Quote
Old 04-02-2013, 09:56 AM   #7
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
im running -1.3L/-1.7R myself. I would like to even it out if possible without LCA's. spec is -1.2 +/- 0.75
supramkivtt2jz is offline   Reply With Quote
Old 04-02-2013, 10:06 AM   #8
OrbitalEllipses
Drives: Attitude
Adjustable UCA, adjustable LCA, or UCA bushings are really your only options here. By the time you get the stock UCA out and press the bushings in/out you could have just replaced either arm with an adjustable one.
Old 04-02-2013, 11:07 AM   #9
subaruatheart
Drives: Whiteout FR-S
Yeah it seems like the bushing kit from whiteline is more of a hassel than spending a couple more hundred on a pair LCAs.
subaruatheart is offline   Reply With Quote
Old 04-02-2013, 11:40 AM   #10
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
I read somewhere on this forum that someone used camber bolts in the rear as well. I think he had to shorten them slightly but they did still work.
Originally Posted by digital_assassin View Post
Ended up picking up these for the time being. They allow 0-3 Degrees of camber either +/-. For the rear bolts you will need to take off about three threads from the inside to make the smooth potion of the shank match the width of the control arm.
The H&R camber bolts I purchased and had them installed by PSI with an alignment. They worked beautifully for both front and rear. I am running -1.5 with .1 total toe on the front and -2 with .2 total toe on the rear. Dropped 1.5" and only adjustment upgrades were the camber bolts from H&R. You'll get more out of these than the whitelines or the OEM. You need 14MM for the front and 12mm for the rear I believe. I bought mine from Perrin. Just talk to Chris or Jeff.
To do a good set of plates and arms you will be in the $1000 range. I would go with the bolts for $48 per pair and be done with it.
From this thread:
http://www.ft86club.com/forums/showt...ghlight=camber
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 04-02-2013, 01:33 PM   #11
robispec
Yes subframe shift and other location lash adjustments
Old 04-02-2013, 08:16 PM   #12
andrew20195
Drives: 2013 Subaru BRZ
This. You can usually get a few tenths out of the factory multilink suspension by jacking up under the frame, loosening (but not removing) all the suspension link bolts, and getting someone to push/pull the tire in the direction you want to move the camber, then retorquing the bolts while the wheel is being held.
andrew20195 is offline   Reply With Quote
Old 04-02-2013, 09:00 PM   #13
robispec
Yup what de mon said.
Old 04-02-2013, 09:37 PM   #14
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
I noticed a visible difference from side to side after installing wider rims/tires. So I purchased some Cusco LCA's for a spring install next week.
At a meet with a couple other 86 owners we noted the same thing but on the opposite side.
Is it best practice to adjust the subframe or just compensate with the adjustments?
CircuitJerk is offline   Reply With Quote
Fortune Auto Coilovers - rears don't go very low? dobbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 07-11-2018 01:29 AM
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 06:06 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
Do Adjustable rear LCA/Camber bushings cause stress? mact Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-16-2013 10:05 AM
What's everyone doing for rears? pheoxs Electronics | Audio | NAV | Infotainment 9 12-12-2012 11:59 AM
