Old 04-01-2013, 12:31 AM   #1
peachch
Drives: White 86 Sport Plus
Spark Plug Broken : CEL P0301 C1201 and U0100
I have 15000 mi on my car. The CEL and Traction control light are both on this morning ans it shows CEL P0301 C1201 and U010. Anyone experiences this? The car run very rough and no power.
peachch is offline   Reply With Quote
Old 04-01-2013, 11:44 AM   #2
andrew20195
Drives: 2013 Subaru BRZ
The P0301 is a misfire in #1 cylinder. That's why your car is running rough. The other codes are likely there because of the P0301. Take it to your dealer and let them diagnose it (hopefully you're still under warranty).
andrew20195 is offline   Reply With Quote
Old 04-02-2013, 12:47 PM   #3
peachch
It is spark plug issue. At this moment, I still do not know the cause of damage.
The spark plug looks very bad. My car has only 15000mi.
Old 04-02-2013, 03:53 PM   #4
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Yea the plug shouldn't be broken like that.
Ranatsu is offline   Reply With Quote
Old 04-03-2013, 02:11 AM   #5
peachch
Two of them went so bad. Here is another plug picture.
Old 04-03-2013, 03:16 AM   #6
atledreier
Drives: GT86 DGM
Wow.... Hope they figure this out. Keep us posted!
atledreier is offline   Reply With Quote
Old 04-03-2013, 04:03 AM   #7
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
Main concern #1: Where is the missing metal from the spark plug. Did they find it or did it fall into the combustion chamber, and how much damage did it do in there.
Main concern #2: Why did the spark plug break like that in the first place.
Question: do you have any modifications, a tune, anything?
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
Old 04-03-2013, 04:11 AM   #8
pauland
pauland's Avatar
Drives: Subaru BRZ
Are those stock spark plugs? What brand are those?
pauland is offline   Reply With Quote
Old 04-03-2013, 04:13 AM   #9
alan.chalkley
Drives: 4wd zooks
The metal from the plugs might just have arced away and not caused any damage.
Was the engine lifted and slid forward to remove the plugs?
alan.chalkley is offline   Reply With Quote
Old 04-03-2013, 09:43 AM   #10
peachch
I could not find missing metal. After I replaced the plugs, the engineruns okay. I have 2.5" mid pipe on.
Old 04-03-2013, 09:47 AM   #11
peachch
No lifted or slid need. You just need 3/8" tool set.
They are stock. I replaced them with HKS M45HL because I do not have other options.
Old 04-03-2013, 09:51 AM   #12
NYNOMAD
Drives: BRZ WRB LTD MAN
[QUOTE=peachch;838153]No lifted or slid need. You just need 3/8" tool set.
No lift to get the plugs out - now that is good news!
Glad it was a simple fix!
NYNOMAD is offline   Reply With Quote
Old 04-03-2013, 09:55 AM   #13
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Can you do a DIY to remove spark plugs without lift/slide the engine? If you can do that i'm sure a lot of people would be appreciated!
chenshuo is offline   Reply With Quote
The Following User Says Thank You to chenshuo For This Useful Post:
microbionic (04-03-2013)
Old 04-03-2013, 10:30 AM   #14
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
wondering about your coil pack..suspect timing setup on your tune, namely exhaust timing
...you running a tune??
Huehuecoyotl is offline   Reply With Quote
