Drives: Volkswagen GTI
How to get that boxer rumble?
I love the deep burbly note a boxer makes, but every video of the brz sounds like a regular 4 cylinder. Does anyone think the aftermarket will make something to give us that sound?
Drives: FRS :D
Yea its called UEL (unequal length) Headers and you are good
The FR-S/BRZ are coming with EL headers which devoids the car of the "boxer rumble" but is more effictive and makes better numbers. So its sound vs performance
Out of the FRS game
Rocket Surgeon
Drives: PSM GGA OMG
Terrorist of Chat Rooms
Drives: 05 E46M3, 06 CT9ARS, FR-S?
just take the whole exhaust system off (cat-back section).
Rocket Surgeon
Drives: PSM GGA OMG
No, then it will just sound like a Honda
#6 | |
Kuruma Otaku
So question is: if we have individual cylinder fuel/spark trim and say EGT feedback, how much closer will an UEL get to EL power-wise when all the cylinders can be tuned better for their individual peak power?
Because titanium. |
#7 | |
Rocket Surgeon
Drives: PSM GGA OMG
Would it be possible to make the same horsepower, but more torque with the unequal length headers?
Rocket Surgeon
Drives: PSM GGA OMG
Only if the UEL header was better designed/built than the EL header. Versus stock? probably. Versus an equally good aftermarket EL header? no.
#10 | |
Drives: FRS :D
I believe this could be done but most likely it would be because you arent extracting the max out of the headers tho for me this is all "in theory"
Out of the FRS game
#11 |
Drives: e30 150 deville etc etc
UEL exhaust headers will raise torque due to some of the cylinders keeping higher backpressure than others...the top end will be lost due to the same reason...Much like chosing a long runner intake manifold vs short runner...
As for making the SAME horsepower but more torque...it would depend on what the constants are there. Do you mean the same horsepower as "brand X manifold" or the same horsepower as you would make using a dynamically identical manifold just one made using a UEL method... If the choice is ONE..then yes of course, you can produce more HP and more torque than a particular brands item by having one produced to suit YOUR car your climate and the rest of the modifications done to your car... If the choice is #2..then no, because the majority of the design will carry over thus keeping the limitations/gains similar in all area's EXCEPT UEL.... The real question is, when will a company produce some variable length headers (i remember seeing a design/patent offer for this a while ago but it was completely unpractical..probably tripling the weight of a standard cast type) |
#12 | |
Site Moderator
Drives: ichi 86 Project
#13 | |
Drives: honda civic si 08
Seriously the only way to get it is with UEL headers, and it might be better than the stock header, but still worse than a good aftermarket EL header. If sound is such a concern, will you to be getting a device that makes a "Woosh" sound so people think you got an ubercool turbo? |
#14 | |
Kuruma Otaku
Because titanium. |
| Next Gen Boxer Engine 4U-GSE | WingsofWar | Engine, Exhaust, Transmission | 33 | 12-10-2011 12:04 AM |
| Porche boxer vs Subaru boxer | Shevon | Engine, Exhaust, Transmission | 22 | 08-10-2011 12:43 PM |
| Is it the first ever FR with a boxer | Cogito8888 | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 04-30-2011 11:12 AM |
| Who would like to see a boxer diesel in the FT-86? | Blokatos | Engine, Exhaust, Transmission | 43 | 06-19-2010 01:04 PM |
| AE86 Boxer | Sleeperz | Engine, Exhaust, Transmission | 9 | 05-05-2010 01:51 AM |
