Old 03-28-2013, 07:40 AM   #1
ft_sjo
Drives: GT86
Anyone else got a noisy ECU?
Hi all
My ECU is noisy. I'm talking about the main ECU under the dash up near the glove box.
I think it's either transistor switching or capacitor noise. It sounds like a light ticking noise which varies with speed and cuts in and out depending on load conditions (which reflects the switch-over between port and direction injection, so it adds up to be injector switching related).
It's pretty annoying, but before I look at getting the dealer to replace the ECU i'd like to find out if anyone else is suffering it.
And before anyone asks, yes I have a noisy high-pressure fuel pump, and no it's not that.
Old 03-28-2013, 08:28 AM   #2
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
theres something similar going on around my glove box. i havent pin pointed the noise but its def coming from inside or around my glove box.
draggin_az is offline   Reply With Quote
Old 03-28-2013, 03:22 PM   #3
strat61caster
strat61caster's Avatar
Were the wipers on? That's the only clicking in front of me that I've noticed.
ineedyourdiddly
Old 03-28-2013, 04:32 PM   #4
joop1987
Drives: 2013 FRS, Raven, Auto
I think there are some relays behind it that click when you set the heater controls, wipers, turn signals, headlights, ... These are usually located under the hood in most cars.
joop1987 is offline   Reply With Quote
Old 03-28-2013, 04:57 PM   #5
wbradley
Sarcastic SOB
wbradley's Avatar
I have never heard physical sounds coming from normal solid state components or IC's. Relays however, do have a moving component which can give of a clicking sound when actuated.
Old 03-28-2013, 05:01 PM   #6
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
buzzzzzz
Huehuecoyotl is offline   Reply With Quote
Old 03-29-2013, 02:54 PM   #7
coastertrav
Drives: Whiteout FRS
Came here to say this. Capacitors and transistors have no moving parts, therefor, no noise (at least not in a low voltage DC applications ie. your ECU).
I'd look to see if there are any relays back there.
coastertrav is offline   Reply With Quote
Old 03-29-2013, 04:57 PM   #8
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Might be a squirrel.
http://www.ft86club.com/forums/showthread.php?t=32275
Apoc is offline   Reply With Quote
Old 04-16-2013, 04:59 AM   #9
ft_sjo
Drives: GT86
Bump
Old 04-16-2013, 08:51 AM   #10
xjohnx
Grip>Slip
xjohnx's Avatar
Are you sure it's not the HPFP? i know mine can be a kind of loud at partial throttle(50-60%), moderate load in the 3-4k rpm range.
Old 04-16-2013, 08:53 AM   #11
CBR600RR
Drives: Raven Black
Noise generator maybe???
Old 04-16-2013, 09:03 AM   #12
ft_sjo
Drives: GT86
I'm not 100% sure, no, and my HPFP is moderately noisy. The thing that makes me think it's the ECU is how it tips in/tips out depending on load and engine speed. E.g. on the over-run it goes very quiet where very small amounts of fuel are being injected, and then once it gets to 1200rpm or so it goes loud again, which is typically where the over-run fuel cut-off has now started to put fuel back in to stop the engine stalling.
I'll have to get a passenger to stick a stethoscope on it to confirm.
Cusco Street Zero A being Noisy...Normal? Norcalscionchamp Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-01-2016 08:45 AM
Engine is quite noisy Rob_g Issues | Warranty | Recalls / TSB 9 10-14-2012 08:41 AM
