Old 03-27-2013, 01:51 PM   #1
husker741
Alignment when springs are installed or after they have settled?
When I install my RCE starter kit lite on my stock struts with my stock rims and tires, should I get an alignment when they are installed? Or should I wait until the springs settle correctly after a few hundred miles?
husker741 is offline   Reply With Quote
Old 03-27-2013, 02:03 PM   #2
swift996
swift996's Avatar
I'd give it a couple weeks/100 miles or so unless you're terribly out of alignment (which I doubt).
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 03-27-2013, 02:06 PM   #3
djdnz
1337
Drives: 2013 BRZ WRB S/C
I waited a week after I had installed lowering springs on my previous car, and then had it aligned. Never had any unusual tire wear in the 80,000km I had the car lowered.
When you initially get the springs installed, your alignment will likely be a little bit out, the steering wheel might be a little crooked but it shouldn't hurt to wait a few days before getting alignment.
djdnz is offline   Reply With Quote
Old 03-27-2013, 02:08 PM   #4
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
I used to drive normally for about a week or so then get the car aligned. I've had cars lowered in the past and never had them aligned and they wrere fine. No uneven wear on the tires and no unusal pulling or handling, but it is a good habit to have the car aligned any time you pull the suspension apart though. Or that's what I've been told over the years.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 03-27-2013, 02:30 PM   #5
SloS13
Drives: 2013 FR-S whiteout
Originally Posted by djdnz View Post
When you initially get the springs installed, your alignment will likely be a little bit out, the steering wheel might be a little crooked.
uuuhhh, WHAT?
SloS13 is offline   Reply With Quote
Old 03-27-2013, 03:09 PM   #6
Racecomp Engineering
A day to a week is fine. Our springs don't settle too much.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Xiijuwa (03-05-2016)
Old 03-27-2013, 03:11 PM   #7
husker741
- Andy
Perfect! So I should have them install the camber bolts and bushings at the same time of spring installation, then wait a week, then align?
Old 03-27-2013, 03:29 PM   #8
Yes, definitely get it all installed at the same time.
I would be fine with getting an alignment anytime within a week.
- Andy
husker741 (03-27-2013)
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 05:41 PM
RCE yellow springs. Expected alignment settings after install. diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-24-2013 02:48 PM
How necessary is alignment after installing new springs? switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-22-2012 11:52 AM
Anyone do their own alignment? TemeCal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-09-2012 11:36 PM
alignment with Eibach springs? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-17-2012 11:34 AM
