Old 03-23-2013, 11:28 PM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
exhaust buzzing 3k to 4k input please!
so have I have the ARK test pipe as well as catback exhaust and have an issue with the exhaust rattling around 3k to 4k when the throttle is pressed more than halfway, so kinda laying in on it. I have checked to see if the bolts were loose and there is no sign of anything being loose at all. I also checked the heat shield on the exhaust manifold and nothing is loose there. Mind you the test pipe does not have a heat shield so there can't be anything going on there. Since I do not have or know the torque specs for the exhaust, I tightened down everything pretty tight with an impact gun. I have noticed something though, which is condensation (not much) going from the test pipe to the catback where the donut gasket is. That portion I really tightened down in fear of it coming loose. Could this be the issue since there is not enough play in the system? Perhaps I over tightened that part of the exhaust? Any input would be great!!!
Note: mind you only in more than half throttle around 3l to 4k the noise happens otherwise it's gone. Otherwise if not on more than half throttle, the exhaust sounds perfectly fine without the noise.
ft86me is offline   Reply With Quote
Old 03-24-2013, 12:19 AM   #2
mswhong
Drives: FT86
there shouldn't be any sort of leakage.. and given that you noticed some condensation at the donut gasket, it might possibly be the linkage between test-pipe and catback that's making the rattle sound.
Call/email ARK and see what their opinion is on it.
mswhong is offline   Reply With Quote
Old 03-24-2013, 12:22 AM   #3
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
You very well could have overtightened something...the exhaust bolts only need to be tightened to 25 ft-lbs...tightening with an impact means they are probably closer to 125ft-lbs which could warp flanges.
Also check clearances around the transmission tunnel and those things, the Perrin had an issue where on some cars the resonator did not have enough clearance between the resonator and the trans tunnel and would hit the trans tunnel and make noise, easily fixed with a couple minor adjustments.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 03-24-2013, 12:44 AM   #4
ft86me
ft86me's Avatar
Drives: 2013 FRS
i'll definitely check that out. thanks man appreciate the info. wow 25ft lbs. fml hahaha. perhaps too late. i'll put it in the air on monday and see what's going on at work. thanks again!
Old 03-24-2013, 12:46 AM   #5
ft86me
ft86me's Avatar
Drives: 2013 FRS
actually there is plenty of room since the resonator is pretty small and i just looked and there is plenty of clearance for both test pipe and cat back. perhaps over tightened
Old 03-24-2013, 12:51 AM   #6
jpit
Drives: Subaru BRZ
What you may be hearing is rasp from the test pipe. That is a common problem. The torque spec for the donut gasket is just 15 lbs.
jpit is offline   Reply With Quote
Old 03-24-2013, 12:55 AM   #7
ft86me
ft86me's Avatar
Drives: 2013 FRS
this is what i was assuming since that tends to happen and there is no cat on the test pipe
Old 03-24-2013, 12:55 AM   #8
ft86me
ft86me's Avatar
Drives: 2013 FRS
so 15ftlbs for the test pipe to the catback?
Old 03-24-2013, 12:57 AM   #9
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I have this problem, the exhaust is hitting the crossmember right in the center of where the rear wheels are. The solution for me was slightly longer stiffer polyeutherane exhaust hangers.
LeeMaster is offline   Reply With Quote
Old 03-24-2013, 12:59 AM   #10
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by LeeMaster View Post
I have this problem, the exhaust is hitting the crossmember right in the center of where the rear wheels are. The solution for me was stiffer polyeutherane exhaust hangers.
i can hear mine coming from the front for sure. it's like the front right. doesn't sound like a rattling on something and plus I have the exhaust hangers wrapped with clamps so they don't sag
Old 03-24-2013, 01:00 AM   #11
jpit
Drives: Subaru BRZ
Yes. I have the same problem with the condensation but haven't been able to completely stop it.
Old 03-24-2013, 01:02 AM   #12
ft86me
ft86me's Avatar
Drives: 2013 FRS
mine is SUPER minimal i mean not even enough for it to drip on the ground. i hit up ark with an email a few minutes ago so i'll find out what's going on next week. they are nearby me so if anything i can take it down there
Buzzing / Compressor Sound from Gas Tank Area Spd229 Issues | Warranty | Recalls / TSB 14 12-06-2013 10:17 PM
FRS-off/rear wheel buzzing... iaclimber4 Scion FR-S / Toyota 86 GT86 General Forum 4 01-31-2013 06:25 PM
Intermittent buzzing from below the steering wheel? brzninja BRZ First-Gen (2012+) — General Topics 12 01-05-2013 10:01 PM
Delete driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 11-15-2012 01:00 AM
buzzing noise from steering wheel FR-S :DK Scion FR-S / Toyota 86 GT86 General Forum 1 10-07-2012 01:52 AM
