Old 06-30-2012, 12:41 PM   #1
Proud of BOXER
Drives: 74 Toyota Celica ST
STI Push Button Start
Japan Parts says that the WRX STI button will work for the BRZ. It's different in that It's red as opposed to the grey one that the BRZ is supposed to have, and it's already available but the BRZ one is still in development. Anyone have more definitive news on this? I'd really rather have a red one.
Proud of BOXER is offline   Reply With Quote
Old 06-30-2012, 03:34 PM   #2
wallace03
wallace03's Avatar
Drives: WRB BRZ
i want the pink one
wallace03 is offline   Reply With Quote
Old 06-30-2012, 06:18 PM   #3
Proud of BOXER
Pink one? There's only this red one, and a grey one for the BRZ
Old 07-01-2012, 05:34 PM   #4
R0ME0
ハチロク
R0ME0's Avatar
Drives: Evo X
How does the gray one look like?
R0ME0 is offline   Reply With Quote
Old 07-01-2012, 06:06 PM   #5
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Most likely coming out with a red one for the future STi BRZ. Might even be interchangeable with our current BRZ assuming the trim doesn't change too much.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 07-04-2012, 03:37 PM   #6
BugeyedWagon
Suby Specialist
BugeyedWagon's Avatar
I have the red Sti button for the BRZ. It is not as simple as just swapping the button assembly because the male connector end of the button has 11 pins rather than the USDM 8 pin.
I am working on a remedy.
I test fitted the button in my BRZ and it looks amazing. I'm excited to get this done and share with everyone what I had to do to make it work.
Old 07-04-2012, 05:48 PM   #7
wallace03
wallace03's Avatar
Drives: WRB BRZ
speedhunters says this one is pink. i also want all the other pink stuff that i can get for the car http://www.speedhunters.com/2012/01/...z_sti_concept/
Old 07-05-2012, 10:41 PM   #8
JPM Coachworks
JPM Coachworks's Avatar
Drives: Honda S2000, Subaru STI
Send a message via AIM to JPM Coachworks
I have the GR STI button in my 2008 hatch and I plan to swap it into the BRZ whenever the gods decree it time for mine to arrive. I was anticipating some problems as mentioned above but generally, those are easily remedied. You will notice that the button shown below features a status LED whereas the BRZ "specific" one referenced above does not. I suspect this is where your additional 3 pins come from as this LED changes states based on...the state of the vehicle.
Alex
JPM Coachworks is offline   Reply With Quote
Old 07-10-2012, 10:48 PM   #9
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Has this progressed any further? I probably cannot place this in my FRS but its interesting to see the work done on this! =)
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 07-10-2012, 11:00 PM   #10
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
I don't think the light on the button would work, therefore the pink button is a better option.
quik1987 is offline   Reply With Quote
Old 07-10-2012, 11:03 PM   #11
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
I would love to switch my start button out some one work on this!
Lee358 is offline   Reply With Quote
Old 07-11-2012, 12:27 AM   #12
BugeyedWagon
Suby Specialist
Yes! I got bored with the all star game tonight and decided to really investigate the wiring issue. Success...sort of!
Here's a Picture:
I have a temporary wiring solution (Simple test wires looped over the pin on one and and plugged into the female connector on the other) that allows me to start and stop the car, as well as starting the accessories with my foot off the brake. I also was able to wire it up for the status LED and STI logos to illuminate, however I could not get the lights in the button to power off even after the car is shut off and locked. In fear of draining my battery overnight, I have temporarily disabled this feature and will go at it again tomorrow.
Old 07-12-2012, 05:06 AM   #13
Sergie
Drives: Toyota 86 GTS
thanks mate, btw how did you take out the original panel? thanks again
Sergie is offline   Reply With Quote
Old 07-12-2012, 10:49 AM   #14
BugeyedWagon
Suby Specialist
I popped the passenger side center stack lower cover (below the knee pad) off. Then I reached in from behind and popped the USB connector out (push forward). The next step is to unplug the connection and push the wiring back through the exposed hole. After that reach into the now vacant USB hole with your pointer finger and pull gently. It may require some tugging a bit, but it will eventually pop out.
On another note, I worked a little more on this last night. I also confirmed via the STI part number on my switch that my switch is in fact the one for Impreza models. Japan parts sells the BRZ button, but you have to be sure to select the ZC6 before adding it to your card to have the right one.
Because I get mine elsewhere, I had to be a little creative to get mine to work. Eventually, I just decided to sauter some jumper to the pins on the button and connect them to the female connector. It works and looks great!
I am a little concerned that I cannot get the red LED illumination to go off when the car is shut off. I plugged my stock USDM button in and it did the same thing (stays on even with power off). Since an LED pulls low voltage, Im not too concerned about it. But can someone please confirm for me whether their stock button stays illuminated all the time?
Thanks!
Push button start Symbiont Cosmetic Modification (Interior/Exterior/Lighting) 5 06-17-2012 01:45 PM
push button start standard? sparrowhawk BRZ First-Gen (2012+) — General Topics 2 03-04-2012 03:52 PM
Push button start general question maxeveland Other Vehicles & General Automotive Discussions 9 02-14-2012 10:13 AM
No push button start a good thing? Syldrin Scion FR-S / Toyota 86 GT86 General Forum 130 12-13-2011 07:06 PM
