Old 03-21-2013, 10:26 AM   #1
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Question about strut brace
I've been thinking about adding a strut brace but wanted to hear from those that have added one. Is there a significant difference in handling? Is one particular brand better than another? Thanks in advance.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 03-21-2013, 10:49 AM   #2
Racecomp Engineering
Not a significant change. You'll get a slight difference in feel, maaaybe a slight reduction in vibration. It will make more of a difference if you already have sticky tires and firm suspension, but IMO it's not a part that is a priority. BUT...they do look kinda cool and it's not something that is going to harm anything. There are just other areas that are priorities.
- andy
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
Propaganda (03-21-2013), russv (03-21-2013)
Old 03-21-2013, 10:57 AM   #3
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
+1 to what RCE said. I have the tri-bar from ft86 speedfactory...as well as FA 500 coilovers (feels much more firm than BCs I've ridden in), and Hankook RS3s. Not a huuuuuge difference. Definitely won't notice it if you just DD your car. On all seasons or less sticky summer tires, your tires will roll a lot more so it won't be as noticeable. I felt a slight difference - it feels a little more neutral now. But as RCE said, how much you notice will depend on other mods as well as how well you know your car.
Propaganda is offline   Reply With Quote
Old 03-21-2013, 11:03 AM   #4
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
This is my opinion:
It depends how hard your setup, drivingstyle, and how much traction your tires have. As you get to the types of tires that far exceed oe grip, I think bushing and chassis flex become more discernable. Once you isolate stuff, like getting rid of big rubbery factory bushes, I think you can better sense stuff like what a bar such as a strutbar does. There is alot of flex in the 3" rubber discs in the front LCA. Putting a PSRS type there really changes the feedback you get from, say, cornering, and if I keep my tire psi firm, yeah I can tell. I suspect something like the robipsec LCA will also allow you to better feel flex in the towers, but all this is oh so very slight.
Adding the r888s, that are like velcro when they are hot, and the koni race dampers too make me able to hold G forces that toss me well against the doors, so yeah, as you increase your build level, it can be functional and not just bling.
Huehuecoyotl is offline   Reply With Quote
Old 03-21-2013, 11:12 AM   #5
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
usually you wont feel shit....I had all my other cars had strut bar mod but didn't feel much difference. mainly it's for looks.
Old 03-21-2013, 01:33 PM   #6
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
The initial design on this car is such that for a daily driven car, you won't feel much of a difference. If you're a more aggressive driver, then the front strut bar will make a little difference. However, given the god awful Prius tires that were so intelligently chosen for our cars, you're not really going to feel any difference until you start making other suspension upgrades, or tire upgrades and decide to take corners the way our cars were designed for.
omegared19 is offline   Reply With Quote
Old 03-21-2013, 01:56 PM   #7
ModBargains.com
ModBargains.com's Avatar
Not a huge performance gain out of it, but it's enough to make you feel like the price tag on it ($180 or so), is totally worth to get one of these from Cusco for example:
ModBargains.com is offline   Reply With Quote
Old 03-21-2013, 03:04 PM   #8
GC_Adam
GC_Adam's Avatar
Drives: '08 Impreza, 03 SV1000S
A hinged (Cusco, Whiteline, etc) strut brace typically won't increase any rigidity. If you want to decrease the engine bay flex by adding a strut brace then look at a solid mount brace (GC, Hotchkis, Etc).
Adam
GC_Adam is offline   Reply With Quote
Old 04-04-2013, 12:36 AM   #9
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
- andy
Which areas would you count as higher priority?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 04-04-2013, 09:22 AM   #10
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
You probably won't feel much if any difference, but that doesn't mean it's not doing anything. If you're pushing the car hard, and/or have other upgrades that stiffen suspension it's appropriate to reinforce/stiffen the chassis some even if you don't feel it.
Old 04-04-2013, 09:35 AM   #11
bushings, a proper alignment, front sway bar, etc.
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
DriftEightSix (04-04-2013)
Rear Strut Brace to fix flexing djliquidsteele Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-15-2013 03:16 PM
My Strut Brace Mod... Andrew666 AUSTRALIA 4 03-04-2013 10:38 PM
Cusco engine brace and strut bar _F-R-S_ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 11-01-2012 04:37 PM
Solid one piece strut bar brace brzzz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-16-2012 01:03 AM
Which Rear Strut Brace? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-21-2012 10:01 AM
