Old 06-20-2012, 05:26 AM   #1
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Question Which Rear Strut Brace?
anyone know who made the rear strut brace that goes under the carpet??
i once saw it here but having trouble finding it again.
cusco, tanabe, carbing all have the strut brace over the carpet.
any idea which aftermarket company was it?
86_ZN6 is offline   Reply With Quote
Old 06-21-2012, 06:23 AM   #2
Jason@Nameless
Jason@Nameless's Avatar
Drives: '88 BMW 535is Turbo
We'll be making one soon. Just finished up the majority of our primary exhaust development (cylinder head to the tailpipe) and I'm switching to chassis engineering right now. I've got 3/5 of the control arms mapped out and laid out in 4130 or 6AL-4V tubing w/ either 4130 or 7075 Heim Joints, and we're moving to the strut tower bars next. Also finished up a set of rear sway bar bushing mount gussets tonight.
Our strut bars are very unique, available in AISI 1020 DOM tubing or potentially a lighter weight AISI 4130 DOM tubing option. We have filed a provisional patent on the machined cups that we use to connect the bars to the car. They ensure that the cup has zero movement before taking up deflection of the chassis.
We're still noodling some ideas on how to route the front bar and triangulate to the factory mount points, but the factory front dual bar setup is without a doubt a suboptimal solution for preventing chassis deflection up front. The reason for the twin mounting locations at each end of the factory bars is because the holes in the bars are nearly 1.5x the diameter of the fastener. Also, the factory strut hat mount points aren't as rigid as the strut top itself.
I will emplore anyone who is looking at strut tower bars to avoid the temptation to buy multi-piece billet aluminum variants that are littering the market. I have seen a wide variety of these designs and they have slotted holes, require you to bolt the bar clevis to the hats (they're aluminum, remember) through slotted holes as well and are effectively nothing more than car jewelry. Our bars are generally a single piece monolithic weldment with independent cups on each of the mounting studs/bolts and usually have a multi-bar configuration with stitch welding between the bars (alternated on the top and bottom of the seam). You won't find a more rigid and functional bar on the market.
I'll be posting up some details soon in another thread.
Jason
Jason@Nameless is offline   Reply With Quote
Old 06-21-2012, 09:08 AM   #3
BR33Z3
BR33Z3's Avatar
Drives: 2013 WRB BRZ
Jason, are you planning on making a Front strut bar that's a single piece and mounts to the firewall??
BR33Z3 is offline   Reply With Quote
Old 06-21-2012, 09:47 AM   #4
old greg
Rocket Surgeon
Drives: PSM GGA OMG
There's no benefit to using 4130 in a chassis brace. It isn't any stiffer than 1020 and if you ever load a brace to the point of yielding, you've got bigger problems than chassis flex.
old greg is offline   Reply With Quote
Old 06-21-2012, 10:00 AM   #5
Jason@Nameless
You've got a good point that they have the same modulus of elasticity. :-) All of our bars currently are 1020. :-P
J
Old 06-21-2012, 10:01 AM   #6
Jason@Nameless
Yep. New thread posted.
J
Cusco Rear Strut Bar PekoPeko DIY (Do-It-Yourself) Guides 25 05-01-2018 10:31 AM
TRD brace set, or Cusco? TuxedoCartman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 01-12-2016 11:58 AM
Tanabe Pics of front and rear strut bar! PrimeMotoring Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 06-11-2012 06:02 PM
Front Strut Tower Bar Question russv Scion FR-S / Toyota 86 GT86 General Forum 29 05-22-2012 02:00 AM
