Old 03-15-2013, 08:18 AM   #1
RocketBunny86ph
Drives: 2013 toyota ft86
Enkei rs05rr x rocket bunny
Hi guys, anyone knows how many MM spacer did they use for the enkei rs05rr in the red rocket bunny. And is it a 5x114 also. Thanks guys!
Currently building the same setup.
http://www.speedhunters.com/2012/10/...ket-bunny-frs/
RocketBunny86ph is offline   Reply With Quote
Old 03-15-2013, 09:35 AM   #2
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Looks like it is at least 25mm. But it could be more, I'm not positive.
Beyer Subaru is offline   Reply With Quote
Old 03-15-2013, 09:57 AM   #3
RocketBunny86ph
Thanks for the reply man. Kinda hard to sort out all of the stuffs that was used just to fit this setup/kit perfectly.
Old 03-15-2013, 10:10 AM   #4
Beyer Subaru
Just always remember to measure twice and cut once.
Old 03-15-2013, 10:12 AM   #5
Dooley
Drives: Asphalt
I thought it was cut once, measure twice, eyeball more cuts.
Dooley is offline   Reply With Quote
Old 03-15-2013, 10:13 AM   #6
EarlQHan
Drives: Subarus
If you have the car, the kit, the suspension, and know the wheel size and offset it's fairly simple.
1. Mock up the fenders
2. Set the car's desired ride height and alignment
3. Measure the distance from the OEM wheel to the desired fender location
4. Do some simple math to figure how large of a spacer you need
Good luck
EarlQHan is offline   Reply With Quote
Old 03-15-2013, 10:13 AM   #7
EarlQHan
Drives: Subarus
Old 03-15-2013, 10:44 AM   #8
ebphoto
Drives: FR-S, NA8, S13
ask kei miura... he's on facebook. i'm sure he'd be more than happy to help.
ebphoto is offline   Reply With Quote
Old 03-15-2013, 10:45 AM   #9
RocketBunny86ph
Good luck
ordered parts :
Rocket bunny kit with gt wing
Enkei rs05rr 18x10 +30 front and 10x10.5 +22 rear
Bridgestone Tires 255/40 front 265/40 rear.
KW V3
Spacers 20mm front 30mm rear
Cross fingers. With this tho. Hoping everything will turn out as planned
Old 03-20-2013, 09:24 AM   #10
Godzilla35
Drives: Nissan GT-R
ordered parts :
KW V3
10x10.5 rear? haha... your build sounds sick! take some pics of the progress!
Godzilla35 is offline   Reply With Quote
Old 01-30-2014, 12:45 AM   #11
mnsayer
mnsayer's Avatar
Drives: LexusGS,Lotus Exige S240,LexusLX570
ordered parts :
KW V3
Any pics of your build? As i am about to order the same wheels, wondering how did it go with the spacers as well?
mnsayer is offline   Reply With Quote
Old 01-30-2014, 01:55 PM   #12
raytrix
Drives: Series 10 FR-S
ordered parts :
KW V3
I believe you need bigger spacers than that.
raytrix is offline   Reply With Quote
Wheel Directory: Enkei RS05RR 18x8.5 +42 dabocx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 206 03-02-2018 05:23 AM
Rocket Bunny FRS in Dubai TAP Auto Parts FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 49 12-04-2012 01:39 PM
Subaru BRZ Rocket Bunny Hawk77FT AUSTRALIA 18 11-26-2012 03:35 AM
Red Rocket Bunny FR-S - Speedhunters RaceR FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 10-12-2012 12:48 AM
Rocket Bunny or Modelista? HELP!!! ShowstoppersUSA Cosmetic Modification (Interior/Exterior/Lighting) 21 08-16-2012 01:23 PM
