Old 03-11-2013, 11:27 PM   #1
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
Dealer disabled DRLs = no high beams?
Like the title says, last weekend I brought my FR-S into the dealer to get a 2nd set of tail lights installed due to the condensation issue, and decided to ask about having the DRLs disabled. The tech says he'll look into it and takes my car in for the install. I get the car back a couple hours later and he says he disabled the DRLs already. Cool, right? Well, tonight was my first time driving after dark and when I flip the stalk to turn on the brights nothing happens. I stopped and checked from outside and when the brights are off there is no light coming from the bulb and when I turn on the brights there is a little glow visible, but not much, and the projectors stay on. I forgot that my car was one of the early models that probably needs the new ECU to disable the DRLs properly. Anyone else run into this?
TL/DR: dealer disabled DRLs without replacing ECU, now the brights are too dim to be effective.
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
Old 03-11-2013, 11:34 PM   #2
getbent
Drives: 2013 FR-S Blue MT
You probably have a early build (like less than 6000 vin). You need to find the TSB on here about this issue, but basically the dealer will replace your ECU with a upgraded ECU that allows you to disable the DRL and keep your high beams.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
The Following User Says Thank You to getbent For This Useful Post:
Sportsguy83 (03-12-2013)
Old 03-11-2013, 11:49 PM   #3
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
This.
Subie is offline   Reply With Quote
Old 03-12-2013, 12:15 AM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
Originally Posted by Subie View Post
This.
That
mashal is offline   Reply With Quote
Old 03-12-2013, 02:21 AM   #5
fistpoint
Drives: Supercharged Golf Cart
http://www.ft86club.com/forums/showthread.php?t=21868
TSB you need is second from the top: DRL Customization.
fistpoint is offline   Reply With Quote
Old 03-12-2013, 04:01 AM   #6
Yruyur
Yruyur's Avatar
Did you make sure he didnt just pull the drl relay?
Old 03-14-2013, 05:32 AM   #7
Nikuku
Butch Queen
Nikuku's Avatar
Drives: '13 Firestorm 6MT Scion FR-S
Send a message via AIM to Nikuku
Just curious- why would you want to disable your DRLs? Just for looks?
#Vegas86
Vegas86 Group Page on Facebook
'13 Firestorm FR-S MT "Ms. Banks"
Twitter/Instagram: Nikuku
Nikuku is offline   Reply With Quote
Old 03-14-2013, 07:41 AM   #8
fistpoint
It makes stalking more difficult for one...
Old 03-14-2013, 06:28 PM   #9
Nikuku
Butch Queen
Nikuku's Avatar
Excellent point!
#Vegas86
Old 03-17-2013, 03:15 AM   #10
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
Had this problem too, they replaced the ecu... Now I lost my running lights... FML
zohare is offline   Reply With Quote
High Beams DC-FRS Cosmetic Modification (Interior/Exterior/Lighting) 13 01-12-2013 11:44 PM
Difference Between $3 DRLS and $40 DRLS? FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 14 12-31-2012 06:05 AM
High beams?!?! gmanculb Cosmetic Modification (Interior/Exterior/Lighting) 12 10-02-2012 05:51 PM
Dealer Killed my High Beams travace Issues | Warranty | Recalls / TSB 9 09-26-2012 01:27 PM
NAV Voice Directions disabled? ShoGun Electronics | Audio | NAV | Infotainment 0 07-15-2012 10:06 AM
