Drives: 13 fr-s whiteout
Frs brake issue.
My frs is noticeably pulling to the right under hard braking at higher speeds.
Could anyone offer opinions or ideas? This sucks. Light braking and it stays in a straight line
I'll be back!!
Drives: 2013 FR-S Ultramarine
Check your tire pressures. Mine pulled hard to the right under acceleration when my rear right tire got a nail in it and dropped pressure pretty quick. Braking will do the same thing.
Nathan |
Drives: 23 BRZ
Have you been running it in the track? Check the pads and fluid.
I have a lot of miles tho, they haven't been easy on the brakes. I'm going to check the pads today...
I'll be back!!
Tire pressure is the same all around, just checked when I saw the post... I hope it's not a failing caliper... Warranty should cover that right?
I'll be back!!
Drives: Attitude
Alignment? Check pads for even wear if you have the ability to do so. Otherwise, it wouldn't hurt to go to the dealer.
Drives: Toyota 86
also check for scratches on the brake rotor as I remember seeing someone get a stone lodged in the contact surface of the brake pad.
Drives: Scion Frs
try rebleeding your brake system before you go tare anything apart, could be a bad line or a steel sliver from manufacturing, when bleeding you should beable to tell if theres a bad line or something plugging it up by the force it takes to put the pedal to the floor, but deffinately try every other possibility before you pull it apart
#10 |
sounds like one side of your caliper is stuck. the guide pins need lubricating every time you replace pads, something thats rarely done. also if the caliper piston pushes out too far (happens when the pads get too low before changing) they have a tendency to seize once pushed back in.
#11 |
First questions to ask: Miles, Mods, Driving Style/Tracked?
From there we can go ahead and start to diagnose things better. -Mike Paisan ![]() 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
#12 |
Drives: White 2013 BRZ Limited 6MT
I'm going to agree that it sounds like bleeding the system is in order. If the problem prissiests, then an inspection of the calipers themselves is the next step. And I'm sure you're like the rest of us, and the calipers are still under warrenty, so it should be free at the dealership.
So drive hard, and keep it at 100 around the corners |
#13 |
Drives: Asphalt FRS
This post isn't what I thought it was. So what's up with the brake sqeeking? I only have 3k miles on my car!
#14 |
Drives: Fr-s 2013 white out
| Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! | Mike@CZP | Brakes, Suspension, Chassis | 348 | 06-01-2018 12:29 PM |
| BBK,BRAKE PAD,BRAKE ROTORS,MASTER CYLINDER BRACE +MORE @ Source,LLC | SOURCE,LLC | Brakes, Suspension, Chassis | 94 | 07-07-2013 10:56 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
| Cold / Wet weather brake issue? | Ingen | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 10-29-2012 11:42 AM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 10:28 AM |
