Señor Member
Flywheel bolt torque?
So this little beauty arrived for me today but i can't find what to torque the bolts going into the crank should be tightened to. Anyone know?
1974 TA22 Celica
2013 86 GT |
Señor Member
Just the flywheel. I have been told a few times that the TODA clutch is just a rebadged exedy unit. Plus i aren't planning on going FI so the std clutch should be fine for me
1974 TA22 Celica
2013 86 GT |
They're plastic region bolts so don't reuse the old ones. I'd wager 50nm +90 +45degrees would be sufficient.
Señor Member
Good to know. Do ARP make replacements?
1974 TA22 Celica
2013 86 GT |
Do these lightweight Flywheels come balanced or do they need to be balanced by a machine shop prior to installing? I ask because for my Vette, balancing a lightweight flywheel was recommended if installing one. Thanks...
Flywheel Balancing Vid = [ame="http://www.youtube.com/watch?v=sl8F_ZtMhNk"]Subaru Flywheel lightening and Balancing - YouTube[/ame]
*Red 2014 SRT Viper GTS
![]() *Whiteout 2013 Scion FR-S(SOLD) *Cyber Grey Metallic 2012 Chevrolet Volt(SOLD) *Black 2010 Victory Cross Country *Black 2008 Chevrolet Corvette 1LT/NPP/Z51/M6(SOLD) |
#8 | |
Señor Member
Checked out the ARP 2013 catalogue and they don't list flywheel bolts for any Subaru engine unfortunately. If i can find the thread specs maybe something would match up though.
EDIT: I wouldn't recommend lightening your stock flywheel. Doing so can weaken it and the last thing you want is a flywheel failure at 7500rpm.
1974 TA22 Celica
2013 86 GT |
Just make sure you don't put drive plate bolts in place of flywheel bolts. The AT bolts are the same length and thread count but they do not stretch. Trying to stretch them will likely destroy your crank or break the bolt off.
#10 |
NASA SpecE30 Racer
I bought new bolts from Subaru when I installed my ACT flywheel/clutch. I believe they are the same part number as for the STI. If nobody gets you the torque specs, I have them printed out of the factory service manual and can post them up tonight.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#11 |
Señor Member
Thats would be awesome. I dont suppose you have the bolt part numbers as well?
1974 TA22 Celica
2013 86 GT |
#12 | ||
NASA SpecE30 Racer
- King Tut
#13 |
Drives: DGM BRZ Limited
I have never in my life seen a TTY bolt used for flywheels. And those torque specs do not have a degree of stretch in the specs... so I don't think they are.
I'm not saying they aren't, but if they are it will be the first I've worked on. Of course, the FSM always recommends replacement parts for critical parts regardless of whether they are requiring replacement. |
| replace flywheel? | Jeong | Engine, Exhaust, Transmission | 41 | 05-19-2022 11:08 AM |
| Flywheel Rattle? | CB762 | Issues | Warranty | Recalls / TSB | 119 | 11-16-2016 10:09 PM |
| Camber bolt torque spec | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-09-2013 10:30 AM |
| SPEC Flywheel | wootwoot | Engine, Exhaust, Transmission | 15 | 11-09-2012 09:08 AM |
| BRZ crash bolt same as Impreza lower strut bolt? | xwd | Tracking / Autocross / HPDE / Drifting | 0 | 07-05-2012 12:19 PM |
