Old 03-04-2013, 12:50 AM   #1
Turdinator
Señor Member
Turdinator's Avatar
Flywheel bolt torque?
So this little beauty arrived for me today but i can't find what to torque the bolts going into the crank should be tightened to. Anyone know?
1974 TA22 Celica
2013 86 GT
Old 03-04-2013, 06:17 AM   #2
Racecomp Engineering
Did you order the complete kit?
http://www.toda-racing.co.jp/en/prod...heel/fa20.html
Mw
Old 03-04-2013, 05:33 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
Just the flywheel. I have been told a few times that the TODA clutch is just a rebadged exedy unit. Plus i aren't planning on going FI so the std clutch should be fine for me
1974 TA22 Celica
2013 86 GT
Old 03-04-2013, 06:32 PM   #4
FirestormFRS
They're plastic region bolts so don't reuse the old ones. I'd wager 50nm +90 +45degrees would be sufficient.
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
Turdinator (03-04-2013)
Old 03-04-2013, 06:37 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
Good to know. Do ARP make replacements?
1974 TA22 Celica
2013 86 GT
Old 03-06-2013, 06:57 PM   #6
FirestormFRS
Not sure.
Old 03-06-2013, 07:08 PM   #7
cplabaunza
Do these lightweight Flywheels come balanced or do they need to be balanced by a machine shop prior to installing? I ask because for my Vette, balancing a lightweight flywheel was recommended if installing one. Thanks...
Flywheel Balancing Vid =
[ame="http://www.youtube.com/watch?v=sl8F_ZtMhNk"]Subaru Flywheel lightening and Balancing - YouTube[/ame]
*Red 2014 SRT Viper GTS
*Whiteout 2013 Scion FR-S(SOLD)
*Cyber Grey Metallic 2012 Chevrolet Volt(SOLD)
*Black 2010 Victory Cross Country
*Black 2008 Chevrolet Corvette 1LT/NPP/Z51/M6(SOLD)
cplabaunza is offline   Reply With Quote
Old 03-06-2013, 07:27 PM   #8
Turdinator
Señor Member
Turdinator's Avatar
Not sure.
Checked out the ARP 2013 catalogue and they don't list flywheel bolts for any Subaru engine unfortunately. If i can find the thread specs maybe something would match up though.
The Toda lightweight flywheel comes balanced BUT I personally like to get my flywheel and clutch balanced together for peace of mind. I have had this done twice now on my old Celica with a Toda flywheel and Exedy HD clutch. The firts time they were already spot on balanced, the second there was only a slight imbalance which was corrected.
EDIT: I wouldn't recommend lightening your stock flywheel. Doing so can weaken it and the last thing you want is a flywheel failure at 7500rpm.
1974 TA22 Celica
2013 86 GT
Old 03-06-2013, 07:49 PM   #9
FirestormFRS
Just make sure you don't put drive plate bolts in place of flywheel bolts. The AT bolts are the same length and thread count but they do not stretch. Trying to stretch them will likely destroy your crank or break the bolt off.
Old 03-07-2013, 12:51 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I bought new bolts from Subaru when I installed my ACT flywheel/clutch. I believe they are the same part number as for the STI. If nobody gets you the torque specs, I have them printed out of the factory service manual and can post them up tonight.
Old 03-07-2013, 05:12 PM   #11
Turdinator
Señor Member
Turdinator's Avatar
Thats would be awesome. I dont suppose you have the bolt part numbers as well?
1974 TA22 Celica
2013 86 GT
Old 03-07-2013, 08:29 PM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I can't find the receipt for the part numbers. The instructions in the manual state this:
Tighten the eight bolts in the order as shown in the figure.
Standard value:T=85N·m {867kgf·cm} {62.7ft·lbf}
The order is 12 o clock, 6 o clock, 9 o clock, 3 o clock, 10 o clock, 4 o clock, 1 o clock, and 7 o clock. Basically pairs across from one another repeated.
The Following 4 Users Say Thank You to King Tut For This Useful Post:
FRS Justin (09-03-2014), GhostOp86 (01-10-2016), poorsche (04-28-2015), Turdinator (03-07-2013)
Old 03-07-2013, 11:10 PM   #13
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I have never in my life seen a TTY bolt used for flywheels. And those torque specs do not have a degree of stretch in the specs... so I don't think they are.
I'm not saying they aren't, but if they are it will be the first I've worked on. Of course, the FSM always recommends replacement parts for critical parts regardless of whether they are requiring replacement.
Coheed is offline   Reply With Quote
replace flywheel? Jeong Engine, Exhaust, Transmission 41 05-19-2022 11:08 AM
Flywheel Rattle? CB762 Issues | Warranty | Recalls / TSB 119 11-16-2016 10:09 PM
Camber bolt torque spec ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-09-2013 10:30 AM
SPEC Flywheel wootwoot Engine, Exhaust, Transmission 15 11-09-2012 09:08 AM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
