Drives: Ultramarine FR-S 6MT
Dealer over tightened wheel studs
I love my dealership 99% of the time. They do a good job, are very friendly and have taken great care of me. However, they rotated my tires at my 7500 mile service and now.. I can not loosen the wheels. I don't have an impact, but I couldn't do it with a 4 way wrench.
Should I ask them to loosen and correctly torque? Do I need to be worried about stud damage? I intend to autocross the car and I think I will lose my mind if I lose a wheel because I didn't nip this in the butt. What do you guys think? Edit: more concerned about possible damage, any opinions on that? I was thinking dealer because they could replace the studs while they're at it.
WUB WUB
Drives: 2013 Firestorm
you shouldn't have to go all the way to your dealership, any tire place could loosen then re-tighten them correctly. not supposed to tighten them down with an impact anyways (according to my teacher in auto-tech)
#3 | |
Drives: 2013 BRZ SWP 6AT Ltd
Did you try to stand on the factory lug wrench? I've never had a lug nut I couldn't remove. The next time that your at the dealer just ask them to only use a torque wrench to factory specs. I have to do this with my guys because I've got aftermarket lugs that you can't use air tools with. |
PROUD OF BOXER
Drives: Raven FR-S
Breaker bar.
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
This is one reason I always mount and rotate my wheels myself. You can get an inexpensive floor jack, torque wrench, breaker bar, and sockets at Harbor Freight for under $100, and have the satisfaction of doing it yourself, and knowing it was done right.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
I usually post drunk
Stand on the wrench. That's what I had to do the first time I did a DIY. Then just do it yourself from now on.
No rice, no life
Drives: 2013 Asphalt FR-S
Do you have a long metal/PVC pipe you could stick on the end of your wrench? That would give you more leverage and it would be much easier to get it loose.
Drives: 2013 Scion FR-S Whiteout 6MT
Most people can "squat" or lift more than their own weight, are u pulling up on the wrench or pushing down? Ie if u weigh 150lbs thats the most u can possibly push down with before u lift urself off the ground, give or take fulcrum points and leverages. but u can most likely lift much more than 150lbs of force on the wrench
Re-member
Drives: Toyota camry
Apply wrench, use car jack under end of wrench, protect the eyes, cross the fingers, and viola.
Nothing decays like progress, and nothing preserves like neglect.
#10 | |
#11 |
Get a stronger wrench lol. Tried the one in the trunk?
#12 | |
Drives: 2013 BRZ Ltd. MT
When bolts are "stuck" like yours, especially steel bolts mated to aluminum, they often need a very sharp RAP; this breaks the fastener free. Where slow, progressively increasing force will lead to bending things, and rounding-off the bolt heads, a sharp RAP (with a hammer, for instance) will free it. There's too much "stiction" at work. Break that "stiction" bond. |
#13 |
Drives: 2008 Honda Fit Vivid Blue Pearl
With a lever long enough you can move the world.
#14 |
Drives: LR BRZ Limited
lesson 1. never go to the dealer for maintenance you can do at home or at a friend's house
| A warning about wheel studs | post_break | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 41 | 05-05-2015 03:07 PM |
| broken wheel studs | Matt Andrews | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 11-06-2012 12:47 AM |
| Small wheel studs | PrinzJ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 10-10-2012 04:47 PM |
| Bolt Pattern, Wheel Hubs and Studs | Jeff Lange | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 03-08-2012 02:49 AM |
