Old 02-23-2013, 04:08 PM   #1
Ingen
Drives: Ultramarine FR-S 6MT
Dealer over tightened wheel studs
I love my dealership 99% of the time. They do a good job, are very friendly and have taken great care of me. However, they rotated my tires at my 7500 mile service and now.. I can not loosen the wheels. I don't have an impact, but I couldn't do it with a 4 way wrench.
Should I ask them to loosen and correctly torque? Do I need to be worried about stud damage?
I intend to autocross the car and I think I will lose my mind if I lose a wheel because I didn't nip this in the butt.
What do you guys think?
Edit: more concerned about possible damage, any opinions on that? I was thinking dealer because they could replace the studs while they're at it.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 02-23-2013, 04:11 PM   #2
wrxgoose
WUB WUB
Drives: 2013 Firestorm
you shouldn't have to go all the way to your dealership, any tire place could loosen then re-tighten them correctly. not supposed to tighten them down with an impact anyways (according to my teacher in auto-tech)
wrxgoose is offline   Reply With Quote
Old 02-23-2013, 04:24 PM   #3
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Did you try to stand on the factory lug wrench? I've never had a lug nut I couldn't remove.
The next time that your at the dealer just ask them to only use a torque wrench to factory specs. I have to do this with my guys because I've got aftermarket lugs that you can't use air tools with.
Beyer Subaru is offline   Reply With Quote
Old 02-23-2013, 04:25 PM   #4
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Breaker bar.
supramkivtt2jz is offline   Reply With Quote
The Following 3 Users Say Thank You to supramkivtt2jz For This Useful Post:
Freeman (02-24-2013), jimmillion (02-24-2013), strat61caster (02-25-2013)
Old 02-23-2013, 04:25 PM   #5
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
This is one reason I always mount and rotate my wheels myself. You can get an inexpensive floor jack, torque wrench, breaker bar, and sockets at Harbor Freight for under $100, and have the satisfaction of doing it yourself, and knowing it was done right.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
The Following User Says Thank You to Miniata For This Useful Post:
moniz (02-24-2013)
Old 02-23-2013, 04:25 PM   #6
#87
I usually post drunk
#87's Avatar
Stand on the wrench. That's what I had to do the first time I did a DIY. Then just do it yourself from now on.
#87 is offline   Reply With Quote
Old 02-23-2013, 06:22 PM   #7
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Do you have a long metal/PVC pipe you could stick on the end of your wrench? That would give you more leverage and it would be much easier to get it loose.
campy is offline   Reply With Quote
Old 02-23-2013, 06:26 PM   #8
jshadeck
jshadeck's Avatar
Most people can "squat" or lift more than their own weight, are u pulling up on the wrench or pushing down? Ie if u weigh 150lbs thats the most u can possibly push down with before u lift urself off the ground, give or take fulcrum points and leverages. but u can most likely lift much more than 150lbs of force on the wrench
jshadeck is offline   Reply With Quote
Old 02-23-2013, 07:43 PM   #9
ahausheer
Re-member
Drives: Toyota camry
Apply wrench, use car jack under end of wrench, protect the eyes, cross the fingers, and viola.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
The Following 3 Users Say Thank You to ahausheer For This Useful Post:
MrTranxD (02-23-2013), Spaceywilly (02-23-2013), TommyFive (02-23-2013)
Old 02-23-2013, 07:48 PM   #10
Ingen
4 way lug wrench, I weigh 220 and pulled up on one side and pushed down on the other. I bent my wrench slightly
Old 02-23-2013, 07:53 PM   #11
jshadeck
jshadeck's Avatar
Get a stronger wrench lol. Tried the one in the trunk?
Old 02-23-2013, 07:57 PM   #12
Porsche
Drives: 2013 BRZ Ltd. MT
Probably made in China.
When bolts are "stuck" like yours, especially steel bolts mated to aluminum, they often need a very sharp RAP; this breaks the fastener free. Where slow, progressively increasing force will lead to bending things, and rounding-off the bolt heads, a sharp RAP (with a hammer, for instance) will free it. There's too much "stiction" at work. Break that "stiction" bond.
Porsche is offline   Reply With Quote
Old 02-23-2013, 08:42 PM   #13
Xenocide117
Xenocide117's Avatar
Drives: 2008 Honda Fit Vivid Blue Pearl
With a lever long enough you can move the world.
Xenocide117 is offline   Reply With Quote
The Following 2 Users Say Thank You to Xenocide117 For This Useful Post:
baldolera (02-23-2013), Synack (02-23-2013)
Old 02-23-2013, 09:42 PM   #14
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
lesson 1. never go to the dealer for maintenance you can do at home or at a friend's house
DuMa is offline   Reply With Quote
The Following 2 Users Say Thank You to DuMa For This Useful Post:
Black Tire (02-24-2013), strat61caster (02-25-2013)
A warning about wheel studs post_break Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 05-05-2015 03:07 PM
broken wheel studs Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-06-2012 12:47 AM
Small wheel studs PrinzJ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-10-2012 04:47 PM
Bolt Pattern, Wheel Hubs and Studs Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-08-2012 02:49 AM
