Drives: 2013 subaru limited wrb brz
BIU (body integragted unit) replace
Anyone every had to replace your BIU because you shorted out something. I think i just shorted out my driver side courtesy light. There is power to it all the time but not enough ground to light the light bulb. The dome light comes on when the door is open but the door light doesn't. Yes i checked the bulb it works fine because i swapped it out with the other side. Hope this unit isn't too expensive don't want to pay big bucks for it. If you did a swap how much did it cost you?
Just a little update. Called Subaru dealer for price check on parts. The BIU is $380 doesn't include labor. Also it is not a part they stock so has to be ordered can take up to two weeks depending on availability. Taking car in for service on Monday to make sure its the part.
Last update for this i took the brz into the dealership to verify if the BIU went bad. It looks like when the door light shorted it fried the ground wire not the BIU. So if your are having light issues in the door make sure your wires didn't get fried or have the dealership check it out for you.
| replace flywheel? | Jeong | Engine, Exhaust, Transmission | 41 | 05-19-2022 11:08 AM |
| Anyone replace rotors yet? | NickFRS | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 01-16-2013 02:38 PM |
| Looking to replace my sedan | carbonBLUE | Other Vehicles & General Automotive Discussions | 5 | 01-11-2013 08:41 PM |
| How to make the body kit sit flush against the body? | JasonCDC | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 01-10-2013 04:07 PM |
| Selling Bespoke Unit and XM unit | ravenfrs | Audio/Visual, Electronics, Infotainment, NAV | 2 | 11-05-2012 07:25 PM |
