Old 02-18-2013, 07:33 AM   #1
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Tune before 1000mi break in?
I'm thinking about getting the FA20Club ECU tune and installing it after only about 300mi on the car. Is this a bad idea and I should wait until I hit the 1000mi breaking in period? Or just go for it?
Bg8780 is offline   Reply With Quote
Old 02-18-2013, 07:43 AM   #2
Foobar
SLO NO MO
Foobar's Avatar
Go for it.
Sent from my Nexus 4 using Tapatalk 2
Old 02-18-2013, 08:04 AM   #3
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
u prolly could, but id play it safe
lbroskee is offline   Reply With Quote
Old 02-18-2013, 09:00 AM   #4
swift996
swift996's Avatar
I think you will be safe but I'd personally wait because you won't be able to explore the tune if you want to break the car in as recommended. I'd hit 1K, enjoy it for a week or two and then get the tune. That's just my $.02, but it wouldn't hurt anything.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-18-2013, 09:46 AM   #5
cruzinbill
Drives: Argento 6spd FR-S
Depends if you buy into the whole break in bs or not. If you do, then no. If you dont then yes, and be easy on the clutch a bit, since it does need a lil break in.
cruzinbill is offline   Reply With Quote
Old 02-18-2013, 10:08 AM   #6
swift996
swift996's Avatar
With modern day manufacturing and component quality, I doubt it's necessary to break in a car or at least it probably has much less significance as it once did. That being said, running a car at low speeds for the first 1000 miles gives a good amount of time to make sure you don't have any defects/issues. I followed the manufacturer recommendation because I plan on hanging on to this car for a long time (hopefully).
Old 02-18-2013, 10:13 AM   #7
cruzinbill
I will be keeping it also, but I simple drove it normal without raping it all the time. I just didnt bother with the whole 4k or less, speed up, speed down gear up, gear down, left, left, right, right... kinda thing.
Ok not that bad, but how some people describe to do it sounds like landing a plane in topgun.
Old 02-18-2013, 10:56 AM   #8
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
I would wait. If something comes up in the first 1k miles like a CEL or any other problem you want the dealer to check out you will have to flash the ECU again before taking it in for service. I'd say finish the break in, swap fluids, then tune. I'm sure you will be happy you waited if you're keeping the car...
chadstyle is offline   Reply With Quote
Old 02-18-2013, 11:39 AM   #9
Dynotronics1
If that happens, just flash back to stock, and your golden
Dynotronics1 is offline   Reply With Quote
Old 02-18-2013, 11:47 AM   #10
Foobar
SLO NO MO
Foobar's Avatar
There is nothing a tune will do for you that will prevent you from still following the recommended break-in procedure. If your concern is about warranty issues, then you'll have that concern well beyond 1K miles.
Get the tune, and keep it under 4K for the first 1K miles, no sudden braking/flooring, etc.
Old 02-18-2013, 07:39 PM   #11
Bg8780
Bg8780's Avatar
Thanks a lot everyone! I think I'm gonna hold off until after the break in. I can't control myself if I had the tune. I'd romp on it way too much.
Old 02-18-2013, 08:58 PM   #12
Mister_Sir
Mister_Sir's Avatar
Drives: 2013 Scion FRS
I may sound stupid asking this but, where do you get the tune? is this something you get done at a dealership or a shop? I've never tuned a car's ECU before... and I've modded mine quite a bit with exhaust and intake, so it could use a tune.
Mister_Sir is offline   Reply With Quote
Old 02-18-2013, 11:28 PM   #13
Lonewolf
Lonewolf's Avatar
Drives: Moped
First, read up on what a "tune" will do, how it is installed, and how it works.
Then decide which option is best for you, a reflash done by Visconti, FA20 Club (or any of the other vendors on here) or a piggyback setup like Unichip. All these vendors have websites where you can order
the tuning equipment, and support to help get the best tune for your needs.
*Generally, dealerships do not do performance tunes, and you might want to avoid announcing it to your dealership for several reasons.
Old 02-18-2013, 11:41 PM   #14
Fnbeast86
Drives: Firestorm red fr-s
Wait it out an break the engine in
Fnbeast86 is offline   Reply With Quote
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
Dynotronics and their E-Tune/ OTA tune. Ricepuddin User/Vendor/Sponsor Reviews, Feedback, Comments 5 12-24-2012 09:53 AM
Break in ipothas Issues | Warranty | Recalls / TSB 11 10-21-2012 04:41 PM
Oil change after break in? oops86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 32 08-03-2012 12:09 AM
How did you break in your engine? WolfsFang Scion FR-S / Toyota 86 GT86 General Forum 4 06-05-2012 01:12 AM
