Old 02-15-2013, 01:45 PM   #1
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
BRZ came by my shop for some work
A fellow BRZ owner came by to get some work done. Added a radar, backup camera and upgraded the speakers. Figured I would share the post I made of it with you guys if you feel like taking a gander at how it all came out and could give ideas if people are concidering a concealed radar system.
http://hurleysautoaudio.blogspot.com...r-speaker.html
Not trying to spam, just figured i'd share. If this violates anything let me know and ill take it down.
Flat Black VW is offline   Reply With Quote
The Following 5 Users Say Thank You to Flat Black VW For This Useful Post:
86X86 (02-16-2013), Allch Chcar (02-16-2013), IloveBaldEagles (02-16-2013), M-17 (02-15-2013), tripjammer (02-16-2013)
Old 02-15-2013, 02:04 PM   #2
theredtape
Drives: civic,vfr,BRZ
Hmmmmmm. A stock back up cam. Did that require any splicing or is it a separate harness?
Because Racecar.
theredtape is offline   Reply With Quote
Old 02-15-2013, 02:22 PM   #3
xjohnx
Grip>Slip
xjohnx's Avatar
Where'd you mount the radar sensor? same spot I mounted mine?
Old 02-15-2013, 02:23 PM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
A number of cameras will work. It requires a couple pins to be added to the stock 16 pin harness. here's a pic of mine installed:
The Following User Says Thank You to xjohnx For This Useful Post:
theredtape (02-15-2013)
Old 02-15-2013, 02:30 PM   #5
mobiusrain
Future BRZ owner ü
mobiusrain's Avatar
Drives: CX-5 (Family Hauler =P)
Nice. Where did you mount the radar receiver unit. Is it behind the lower edge of the bumper fascia?
mobiusrain is offline   Reply With Quote
Old 02-15-2013, 02:38 PM   #6
theredtape
Nice. It appears we have the same car :p.
How much did it cost you? Do you have a pin-out for adding those leads? Any suggestions for cameras? Were they just crimp on pins?
Because Racecar.
Old 02-15-2013, 02:41 PM   #7
M-17
Ninja Cat Mod
M-17's Avatar
I like how the radar system was installed and nice write up too.
Old 02-15-2013, 02:44 PM   #8
xjohnx
Grip>Slip
xjohnx's Avatar
The pins slide in the OEM harness. This post has all the info you should need, look for info from svxdc.
I went with the Accele over the Rydeen Mini Duo because it's a lower profile/less obtrusive looking install. My post on page 4 or 5 of there has a link to crutchfield where i got it for ~$100ish.
http://www.ft86club.com/forums/showthread.php?t=17020
Old 02-15-2013, 02:45 PM   #9
Flat Black VW
Honestly, I work in the front of the shop, we have 6 installers in the back that do the work. I have no idea where the mounted the radar receiver but I believe it is somewhere behind the bumper on the lower portion. Similar to where xjohnx mounted his
Old 02-15-2013, 02:45 PM   #10
xjohnx
Grip>Slip
xjohnx's Avatar
I believe so. Here's a writeup on my install of the same system minus jammer heads (just Bel instead of escort), it has pictures of the radar sensor mounting.
http://www.ft86club.com/forums/showthread.php?t=25140
Old 02-15-2013, 05:07 PM   #11
swag
swag's Avatar
Drives: 2013 Ltd A/T BRZ
How much was this whole process (back up cam + radar kit and install)? I would really consider this...
swag is offline   Reply With Quote
Old 02-15-2013, 06:07 PM   #12
Flat Black VW
its not too bad, you can run the back up camera wires with the rear radar diffuser to save some time. If you know what you are doing with the radar install it would take 3-4 hours. More depending on level of inexperience.
Old 02-15-2013, 08:39 PM   #13
Aloxi
Drives: BRZ WRB Limited
lol no price quote? did the person come with the backup camera equipment or did you supply it? the shop near me wouldn't give me a price quote over the phone, said i had to bring it in and depends on hour(s) of work. wanted to just supply my own equipment and pay for the labor since i'm fairly new to this
Aloxi is offline   Reply With Quote
Old 02-16-2013, 08:40 AM   #14
Skippman
Skippman's Avatar
Drives: GBS BRZ Limited
Are the speakers running off the factory amp or did you install an aftermarket? What are you using as a cross over?
Skippman is offline   Reply With Quote
Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts serial gixxer Wheels and Tires 41 03-29-2013 04:14 AM
New Shop Toy Car speedygo1369 Mid-Atlantic 4 12-17-2012 10:55 AM
First Oil Change to the shop cantaloupe Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 11-21-2012 04:41 PM
WGP is your shop for the BRZ/FRS Doug@WGP Engine, Exhaust, Bolt-Ons 0 08-24-2012 01:09 PM
Are 17" wheels too big? Might work 16's work a little better? rogerdalien Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 05-10-2012 11:09 PM
