Drives: 07 Corolla CE
Are 17" wheels too big? Might work 16's work a little better?
Stock 17's are fine, I'm sure, but for those who want an additional aftermarket set (maybe dedicated summer tires,) are you considering 16 inch wheels as well?
What are some advantages of 16's? Well, look aren't one but performance might be. 1. 16's can weigh as little as 12 lbs. 2. There may be more tire choices in 16's and they might be cheaper too. 3. 16's might absorb the bumps better before sending the shock to the upper suspension. 4. Many 16' tire choices are lighter. 5. 16's are cheaper. Do you think 16's will clear the rotors and calipers? Based on the photo, can you tell? Last edited by rogerdalien; 04-16-2012 at 03:55 PM. |
Site Moderator
Drives: ichi 86 Project
iirc someone was saying rotor was same size as WRX, so yes, 16's will clear em.
I'm planning to put GC's 5 spoke gold wheels (16's) on my FRS/BRZ for all reason tires & regular 17's for summer tires |
Site Moderator
Drives: Stuff
16s will clear as noted above.
IMO tire sizes aren't ideal for 16" because of the gear ratio increase. I like shortening gearing though, not making it taller so YMMV.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#4 | |
That Guy
Drives: 2013 asphalt FRS MT
You wont change the gearing at all if you keep to the same outside diameter of the tire. 16's will just have a taller side wall. |
#5 | |
Site Moderator
Drives: Nissan GTR
no, i'm putting 19"s on
Site Moderator
^19's? So tires are like 255/30-19? Oh~ that won't be fun ride
#8 | |
Site Moderator
Drives: Stuff
Here's what I made a long time ago: ![]() 245/45/16 is very close.. if you want to run R comps only. Otherwise, I think the shorter gearing of the 235/40/17 plus the additional width will offset the wheel weight difference compared to 225/50/16s. Only time and testing will tell for sure though.
-Dave
#9 | |
That Guy
#10 |
Drives: FR-S, Exige S, Miata
I think 225/50/16 looks promising. Its just a little bit taller. I'm concern that the 235/40/17 is a little too wide and may change the character of the car slightly.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield '95 Miata (Montego Blue) |
#11 |
Drives: Beater
#12 |
Site Moderator
Just go 18's
#13 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
This car is small. 18s will look plenty big, with 19s looking like donks. Not to mention a 215/45 sidewall is on the smaller side of things to begin with. Take an inch out of that and the ride will suck. I wouldn't go bigger than 18s on this car. And performance-wise, more and more shops are thinking 17s might be the larger you want to go.
#14 |
Drives: Nissan GTR
most of the demo cars u see are all running 19"
if you really care about ride, just get a camry. this is a sports car |
| UK work | Giccin | EUROPE | 5 | 02-09-2012 01:21 PM |
| Got a little bit of work done on my S14 today | MrVito | Other Vehicles & General Automotive Discussions | 23 | 01-15-2012 10:00 PM |
| Off to Work! | Exage | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 09-16-2011 11:04 PM |
| Interior Work | S2KtoFT86 | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 10-29-2009 06:33 PM |
| Does anyone work for Toyota? | MTD | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 10-25-2009 07:40 PM |
