Old 11-14-2012, 03:52 PM   #1
cantaloupe
Drives: brz
First Oil Change to the shop
Can I bring in my car to a shop that does oil changes and they'll take care of everything? Or do I need to bring in my own oil? I'm not sure if shops carry the correct oil for the BRZ. It's already difficult finding the correct oil to buy online...Do I also need to provide them a filter/gasket? Anything else I need? Thanks!
cantaloupe is offline   Reply With Quote
Old 11-14-2012, 04:55 PM   #2
Estey
Drives: Scion FR-S, Ultramarine
The shop will take care of everything, all you need to bring in is the cash, lol. Im sure any shop will carry the correct oil as well. Nobody goes out and buys the oil and filter and then takes it to a shop, at least i wouldnt, id just do it myself if i had to buy everything beforehand
Estey is offline   Reply With Quote
Old 11-14-2012, 05:03 PM   #3
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
Customers bring in their own oil to my shop all the time... it saves you money! We charge 15$ to change customers oil that bring their own oil/filter in
but you can have them do it no problem just bring cash and request specifically 0w20 full synthetic
JesseE is offline   Reply With Quote
Old 11-14-2012, 05:34 PM   #4
cantaloupe
Drives: brz
Also, is it okay if I wait until 7500 miles to do my first oil change? I don't track my car or drive it very hard...but it seems like the general consensus on this board is to do their oil change as early as possible. But if the manual says to do the first one at 7500 miles, I'm sure its ok right??
Old 11-14-2012, 05:35 PM   #5
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Yes you can wait.. That is the recommended interval.
Ranatsu is offline   Reply With Quote
Old 11-14-2012, 05:48 PM   #6
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I did
Picked up a (free) filter when I bought the car, got some oil a week later. Went to change my oil and realized the car didn't go up my rhino ramps. The dealership changed it on their lift for free.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 11-14-2012, 11:46 PM   #7
Estey
lol, i guess it could save you money when youre using synthetic. I had a truck before this car and buying conventional oil was more expensive than what an oil change would cost if i took it to the shop
Old 11-14-2012, 11:49 PM   #8
Estey
Originally Posted by Laika View Post
I did
I just realized I cant do my own oil changes anymore, haha, all i had to do was slide under my tacoma
Old 11-15-2012, 10:42 AM   #9
bluesubie
I would at least bring my own OEM oil filter. If the aftermarket filter explodes and causes engine damage, you're not going to be covered under warranty.
-Dennis
bluesubie is offline   Reply With Quote
Old 11-15-2012, 11:48 AM   #10
JesseE
JesseE's Avatar
-Dennis
lol never in the last 8 years working at shops have I seen an oil filter explode... or heard of it, and i've seen some cars go 30k+ in between oil changes
The Following 3 Users Say Thank You to JesseE For This Useful Post:
Le86 (11-15-2012), LeeMaster (11-21-2012), Wes (11-19-2012)
Old 11-15-2012, 01:31 PM   #11
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
If you want a more healthy engine after break in (1000) miles I'd recommend changing it you most likely have small flakes of metal floating around I'd drop the oil after 1k and then wait the next 7500 interval.
DanoFA20 is offline   Reply With Quote
Old 11-15-2012, 01:34 PM   #12
cnk
Drives: '13 DGM BRZ Limited
I did
Pick up the low profile Rhino Ramps and you'll be all set. I used them and 2 jack stands to install my headerback exhaust without any rubbing or issues. The alternative is to build a step-up with some wood.
cnk is offline   Reply With Quote
Old 11-15-2012, 04:03 PM   #13
bluesubie
Someone posted on Edmunds several years ago that he had an engine fire due to a faulty oil filter. He was upset that SoA wouldn't honor his warranty. Sure, the chances are extremely slim but it's not worth the risk IMO.
-Dennis
Old 11-15-2012, 11:16 PM   #14
NicholasByrd
NicholasByrd's Avatar
Drives: AUDIQ7
There are many shop which do great job but there are some which will only take more money from you, so its all up to you to select good shop or you can take it to the companies servicing center.
NicholasByrd is offline   Reply With Quote
DIY BRZ / FR-S Oil Change RallySport Direct DIY (Do-It-Yourself) Guides 169 09-01-2018 02:42 AM
When should i do an oil change? Ayaz2589 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 112 03-15-2013 01:25 PM
First Oil Change Jehuty77 CANADA 14 08-09-2012 11:54 PM
Took my car in for an oil change... joshua BRZ First-Gen (2012+) — General Topics 25 08-04-2012 09:32 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 04:44 AM
