Old 12-15-2012, 04:21 AM   #1
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Front Spring Diameter
The Ground Control Camber Plates website requests the "Spring Diameter (I.D.)". Swift Springs makes springs in 3 different diameters in metric: ID 60mm (2.25") 65mm (2.5") 70mm (2.75"). So if I'm going the Swift Spring route which i.d. do I want? What does the inside diameter refer to?
Old 12-15-2012, 09:26 AM   #2
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
No, I am not referring to their forthcoming BRZ/FR-S springs.
+1 on this. Does anybody know what diameter swift springs are needed to fit BC racing coilovers? I want to change to swift springs from the BC springs, I just don't know the info on them. Anyone did the BC coilover with swift springs already?
Tye300 is offline   Reply With Quote
Old 12-17-2012, 12:06 PM   #3
wparsons
wparsons's Avatar
I'm pretty sure all the coilovers are 2.5" springs.
flickr
Best Spring Rate please help whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-30-2012 09:02 PM
Exhaust Pipe Diameter fmsida Engine, Exhaust, Transmission 9 09-27-2012 04:46 PM
Reverse lock out diameter? Moddiction BRZ First-Gen (2012+) — General Topics 6 09-01-2012 11:04 AM
FRS exhaust tip diameter? empower-auto Engine, Exhaust, Transmission 8 07-12-2012 10:36 PM
Exhaust tip fra diameter tintumz22 Cosmetic Modification (Interior/Exterior/Lighting) 1 07-04-2012 04:31 AM
