Drives: Firestorm FR-S 6MT
Scangauge xgauge code for oil temp, seat belt beep disable, and more
Working code for FR-S/BRZ/86:
Code:
Gauge Unit TXD RXF RXD MTH Note Oil temp C 07E02101 010702E80324 3008 00010001FFD8 Required FW 4.05 or higher Oil temp F 07E02101 010702E80324 3008 00090005FFD8 Required FW 4.05 or higher Precise Fuel Level % 07C02129 046105290000 2808 000100010000 Faster refresh rate Precise Fuel Level US Gallons 07C02129 046145290000 2808 052900640000 Faster refresh rate Precise Fuel Level Liters 07C02129 046145290000 2808 01F4000A0000 Faster refresh rate Seat Belt Beep Query 07C021A7 046115A70000 2808 000100010000 C0 for stock, 00 for disable Seat Belt Beep Disable 07C03BA700 047B15A70000 2008 000100010000 Should return 0000. Replace '00' in the TXD with 'C0' to go back to stock. Relative Throttle Position % 07E00145 044185450000 2808 03E800FF0000 Absolute Throttle Position % 07E00147 044185470000 2808 03E800FF0000 Fuel Pressure PSI 07E00123 046105230000 2810 006400450000 Fuel Pressure MPa 07E00123 046145230000 2810 000100010000 Here is an example of how to make use of the doc I created: From the Xgauge cansf list, the short Term Fuel Trim Bank 1 has the TXD 07E00106. The 01 (07E00106) is the mode #. The 06 (07E00106) is the PID. Now look at the doc I attached. It shows the PID 06 is supported, which means that xgauge code works on our cars. The PID 07, On the other hand, is not highlighted on the list. That means the Short Term Fuel Trim Bank 2 is not supported. Thank you Andery for finding the PID and torque’s code for oil temperature. Without him, I don’t think I can get the oil temp for xgauge.
2013 Scion Firestorm FR-S MT
#2 |
Drives: GTS 86 6AT
You are amazing!
Thanks for figuring this out! |
#3 |
Drives: GTS 86 6AT
Not sure if my the codes would vary by locality, but on my scangauge I had to alter one value in the MTH:
MTH 00010001FFD8 |
#4 |
Jonnyboy, thank you for catching my typo. Yeah, it should be 00010001FFD8. It has been a long day. Anyway, the 1st post was corrected.
#5 |
Drives: 86 GTS
worked for me... a million thanks!
#6 |
Drives: 86
Sorry for bring a noob. Can you also post the steps to setup in the scangauge?
Thanks in advance. Edit: never mind, found some instruction online and Weill try it later. Last edited by Nardi330; 02-07-2013 at 07:16 AM. |
#7 |
Boosted
Drives: Sideways
The IA is intake air temp?
What's WT, water?
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
#8 |
I've had my eye on the ScanGuage for quite awhile, this is great. By the way, will the Scanguage fit in the slot under the a/c controls? It looks close, maybe not for the push button start equipped cars but perhaps the ones without.
#9 | |
Drives: TIE interceptor; BRZ13
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
#10 | |
#11 |
You can set the The ScanGaugeE the same right? Since is more than an 1" shorter should fit b/w start button and usb
#12 |
So I couldn't find my tape measure but with a shitty ruler I found that there is plenty of width for the standard unit. However, height is an issue and you may have to remove or trim the rubber in the slot. The height of the slot without that rubber is over 1.5" though so it can work. My other concern is the display contrast - can you see the display clearly from the drivers position if it were installed there flush with the dash?
#13 |
Drives: 86 GTS
#14 |
Drives: 86 GTS
here is a pic I found on these forums somewhere
Ill have to look into the scangauge E, hopefully it will fit in the start button models. I pinched this scangage from my other car anyway.. |
| FT-86 low temp THERMOSTAT | ft86-UAE | Engine, Exhaust, Transmission | 52 | 08-30-2016 03:46 PM |
| A/C Oil/Water temp gauge | Exhaust | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 02-07-2013 01:19 PM |
| Engine oil temp now available in Torque App | Yruyur | Engine, Exhaust, Transmission | 8 | 02-03-2013 10:52 PM |
| exterior temp. gauge off? | Rayme | CANADA | 8 | 01-23-2013 09:06 PM |
| Simple Oil Temp. Gauge | Sportsguy83 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-19-2013 08:25 PM |
