Old 01-23-2013, 09:33 PM   #1
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
Dual intake cones? Just an idea.
I've been playing with the idea of doing some kind of DIY intake system and thought i'd bounce my latest idea off the general public. Here is a list of parts that i've found in order coming off the throttle body.
For the vacuum line:
http://www.jegs.com/i/Spectre/865/8707/10002/-1
MAF sensor:
http://www.jegs.com/i/Spectre/865/94...-1#accessories
"Y" pipe:
http://www.jegs.com/i/Spectre/865/94...oductId=769283
45's:
http://www.spectreperformance.com/in...-polished.html
And a couple of K&N cones:
http://www.knfilters.com/search/prod...x?Prod=RR-3003
obviously i'll have to make my own brackets, but that shouldn't be too difficult. I know i know, the performance gains will be minimal at best, but i've always like the look of this type of setup.
Can anybody see any totally obvious "cons" that i'm overlooking?
What do you all think of the idea?
Trashed675 is offline   Reply With Quote
Old 01-23-2013, 09:51 PM   #2
dorifuto
If in doubt,flat out
dorifuto's Avatar
Drives: 2013 brz
Maf placement is critical. It takes Alot of r&d to make a functional intake that actually makes power. I you have access to a dyno or software that can show if you are leaning out then go for it.
dorifuto is offline   Reply With Quote
Old 01-23-2013, 09:53 PM   #3
Visconti
Drives: 05 STi
Looks cool
Visconti is offline   Reply With Quote
Old 01-23-2013, 09:54 PM   #4
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
These were common in the Vette world. They really didn't offer any additional gains over single-cone systems. My .02 & YMMV...
They do look neat, though!
GTB/ZR-1 is offline   Reply With Quote
Old 01-23-2013, 10:06 PM   #5
Trashed675
Trashed675's Avatar
I've got the torque app and a bluetooth ODB2 adapter so i'll be sure to check the AF ratio's before and after. Sadly, no dyno anywhere nearby.
Old 01-23-2013, 10:23 PM   #6
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
I dont know much about how it would work or how to tune it properly but I say go for it, would be interesting and its always good to see more people trying new things
Flat Black VW is offline   Reply With Quote
Old 01-23-2013, 11:38 PM   #7
Trashed675
Trashed675's Avatar
Thats kind of been my only reservation, the closest place to get anything tuned is from Perrin about 4 hours north of me. Not exactly convenient.
Old 01-25-2013, 02:52 AM   #8
wWaldo
Drives: Asphalt Frs
common on BMW 335s ...
wWaldo is offline   Reply With Quote
Old 01-25-2013, 03:21 AM   #9
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
Seems like heat could be an issue or do you have plans for heat shielding and/or venting ?
Ravenlokk is offline   Reply With Quote
Old 01-25-2013, 06:13 PM   #10
Trashed675
Trashed675's Avatar
I wouldn't think it would be any more of an issue then any other CAI/short ram. But a heat shield wouldn't be a difficult addition.
Old 01-25-2013, 06:23 PM   #11
JDMenrique
DEEEERP
JDMenrique's Avatar
What did you attach? I can't see it
JDMenrique is offline   Reply With Quote
Old 01-25-2013, 07:20 PM   #12
Trashed675
Trashed675's Avatar
Something along these lines:
http://i151.photobucket.com/albums/s...Buick074-1.jpg
Old 01-27-2013, 11:51 AM   #13
Basti
Basti's Avatar
I'd thought about something similar already, too.
However, for the left side, I'd prefer a mirrored OEM airbox as an addition.
The space behind the bumper seems to be laid out exactly like the one on the right (where the airbox originally sits), so that should be practical.
However, there's the issue of a mirrored airbox not actually being available...
Alternatively, one may stick to the Y-design for the intake but move the filter to the center joint and have the left and right ducts act as intake pipes only...
Basti is offline   Reply With Quote
Old 01-27-2013, 04:18 PM   #14
xcelir8brz
Drives: 2013 BRZ Limited
Tried it this summer already. The car bogged (i.e. too much air flow). This was part of my R&D intake venture.
xcelir8brz is offline   Reply With Quote
Pivot dual gauge ANREX Cosmetic Modification (Interior/Exterior/Lighting) 39 03-01-2014 06:19 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
True Dual Exhaust? jm1681 Engine, Exhaust, Transmission 17 10-07-2012 11:47 PM
Red Toyota 86 TRD (dual exhaust) just86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 04-04-2012 08:48 PM
