Old 01-23-2013, 03:55 PM   #1
F-T
F-T's Avatar
Drives: FRS
Anyone else get shocked from static??
If I wear a sweater... when I get out of the car I get shocked when I close the door! The seats generate static electricity... just wanted to know If this happens to anyone else.
Sent from my SPH-L710 using Tapatalk 2
F-T is offline   Reply With Quote
Old 01-23-2013, 03:57 PM   #2
HunterGreene
Hail Magnet
HunterGreene's Avatar
Also, the sky is blue, clouds are white, and it gets colder in the winter. I've had static with every car I have owned.
Edit: I should say, with cloth seats. I've never owned a car with leather seats.
Old 01-23-2013, 03:58 PM   #3
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
You can push on the window instead of the door to close it without getting shocked.
Xanatos is offline   Reply With Quote
Old 01-23-2013, 03:59 PM   #4
ExWhyZer0
ExWhyZer0's Avatar
Drives: Whiteout FR-S M/T
I've been shocked twice today by my car getting out of it -_-.
ExWhyZer0 is offline   Reply With Quote
Old 01-23-2013, 04:00 PM   #5
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Some cars are static-prone, just like your sweater is more prone than a polo. The process of egress usually has you rubbing across materials that create static. You'll notice cars with more leather generate less static, for example.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 01-23-2013, 04:09 PM   #6
HunterGreene
Hail Magnet
Thats exactly it. As you guys may know, the rubbing of one fabric (your sweater/shirt) against another (car seat fabric) creates an electrical potential, which is discharged when you touch something metal (the car door) hence the static shock.
While touching the glass does prevent the shock, you may still discharge on the next metal surface you touch. Its been my experience that if you touch metal as you are exiting the car (putting your hand on something metal before you get out of the seat), you usually won't get shocked because you have grounded yourself beforehand.
SCIENCE!
Old 01-23-2013, 04:12 PM   #7
gunmetal5
gunmetal5's Avatar
Drives: FRS - MY13
Another tip: after getting out of the car, before closing the door, touch the body with your nuckles, it'll discharge you without the shocking feeling.
gunmetal5 is offline   Reply With Quote
Old 01-23-2013, 04:37 PM   #8
marky
marky's Avatar
Drives: 2020 BRZ tS #54
Yup E-Brake tip zapped me
Old 01-23-2013, 04:57 PM   #9
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
I shock myself all the time.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 01-23-2013, 04:59 PM   #10
HunterGreene
Hail Magnet
I think they mean the electrical kind, not what you do in the privacy of your own home.
Old 01-23-2013, 05:56 PM   #11
Squishy86
Squishy86's Avatar
Drives: Your Car
Its horrible when you work valet and get shocked whenever you close a door or even hand keys to someone.
Squishy86 is offline   Reply With Quote
Old 01-23-2013, 06:12 PM   #12
V1B
V1B's Avatar
Drives: Scion FRS
Many times
V1B is offline   Reply With Quote
Old 01-23-2013, 08:18 PM   #13
zooki
Drives: waiting on a 2021...
Even if I open the door, reach down and touch the ground, I STILL have enough static electricity built up to throw a visible arc between my fingers and the window. I wonder if if has something to do with the tint material? Strange...
zooki is offline   Reply With Quote
Old 01-23-2013, 08:34 PM   #14
MarcusM117
I did it twice in a row with a visible arc as I was complaining about being shocked. My fault for wearing wool!
~2013 Scion FR-S~
~2004 Honda CBR600RR~
~Skip Barber Grad~
MarcusM117 is offline   Reply With Quote
Static on the radio... frsguy707 Southern California 6 01-08-2013 01:59 AM
Radio static in reverse (AT)? finch1750 Issues | Warranty | Recalls / TSB 2 11-14-2012 08:12 PM
Issue: Static!? JDMSushi AUSTRALIA 20 08-29-2012 05:28 AM
static/interference w/ USB to iPhone4 Bobasaur Electronics | Audio | NAV | Infotainment 3 08-17-2012 07:59 PM
