Old 01-19-2013, 01:26 PM   #1
NOHOME
Drives: RAVEN
Windows no longer open/close when door opened
Did a quick search on the faults forum and did not find anything.
When I bought the car, everytime I opened the door, the window used to do a little dance where it went down about an inch and then went back up when I closed the door.
My original thought was "Wonder who the idiot was who designed that knowing the car would be sold in cold climates"
So sure enough, the windows have stopped doing the open/close dance. Not great for a car that has to park outside. It is not possible to close window unless you are inside, so I let passenger out, finish closing that window and then have to leave the DS in the sligthly lowered position.
Is this a programing thing or a sensor thing? While I find window open/close threads that are related to programing, I did not see this one addressed?
Anyone else have this?
EDIT
Found answer. Another common issue.
NOHOME is offline   Reply With Quote
Old 01-19-2013, 01:30 PM   #2
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Read under the Technical Topics :: Issues|Warranty thread.
Also, if you buy a car, you should read the owner's manual.
And... dont be lazy, do some diggin first.
chenshuo is offline   Reply With Quote
Old 01-19-2013, 02:48 PM   #3
EBMCS03
Drives: Argento FR-S
Originally Posted by NOHOME View Post
EDIT
Probably should post the answer here too or a link to it so the next time someone comes across this thread by searching they would have found the answer.
EBMCS03 is offline   Reply With Quote
Old 01-19-2013, 03:45 PM   #4
Sco2355
Check the little "switch" in the door jam to make sure it isn't loose or broke. I had to loosen it to keep my windows up when they got tinted and tighten it back down when we were done. Just a thought.
Sco2355 is offline   Reply With Quote
The Following User Says Thank You to Sco2355 For This Useful Post:
Nicky (04-18-2014)
Old 01-19-2013, 03:48 PM   #5
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
You mean this one?
http://www.ft86club.com/forums/showt...ghlight=window
or this:
or these:
pheoxs is offline   Reply With Quote
Old 01-19-2013, 04:04 PM   #6
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
That's a stupid thought. If you want to break your frameless window, be your own guest.
Old 01-19-2013, 05:02 PM   #7
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
I see a thread smiting in the very near future coming on.
Exhaust is offline   Reply With Quote
Old 01-19-2013, 05:07 PM   #8
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
I think his point was maybe use normal framed windows??? So maybe, you know, they work when it's cold out??? Obviously this hasn't happend to you. It happened to me at 4:30am when leaving for work when it was cold as a mofo out. The window stuck, then rolled down halfway, then when I tried to roll it up, it rolled all the way down and wouldn't roll up. Pretty fun way to spend the hour drive into work...when it happens to you, you'll change your tune...
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
Old 01-19-2013, 05:26 PM   #9
FRiSson
Drives: FR-S MT
This is a safety feature with a quick reset required. Turn engine off. Turn key to "on" posiiton. Push down on window switch twice in quick succession. Should work normally after that.
FRiSson is offline   Reply With Quote
Old 01-20-2013, 09:11 AM   #10
NOHOME
Drives: RAVEN
I happen to live in a place where it gets cold and windows and doors freeze up on a regular basis.
When I fist saw this feature in June, I had to wonder what was going to happen after an ice-storm and the car was covered in a layer of ice. Something would have to give.
For those who are not aware, the windows seem to re-program when it goes below freezing. am going to guess that this is some kind of a failsafe mode to protect the window or the mechanicals?
The problem is that it leaves the window down far enough that you can get water in the car. Since you probalby wont notice that the window has reprogramed itself your first indication after a good rain is going to be a wet interior.
And to those who are emotionally crippled by my method of asking for help first and THEN go searching, please, if you don't want to help, just dont write anything. I did find a solution and others were helpful. Thank you to those that actually had some information.
Old 01-20-2013, 09:14 AM   #11
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Here's a 5 minute fix. Do it and forget about that problem forever.
http://www.ft86club.com/forums/showthread.php?t=25229
Rayme is offline   Reply With Quote
The Following User Says Thank You to Rayme For This Useful Post:
NOHOME (01-20-2013)
Old 01-20-2013, 12:14 PM   #12
NOHOME
Drives: RAVEN
Found your fix earlier today. Thanks for taking the time to post it. I think that is going to be the answer.
Of course knowing me, I will procrastinate for a while or at least until a nice day comes along. I hate working in the cold and my nice warm shop is full of sleeping prima-donna British tin!
Old 01-20-2013, 12:45 PM   #13
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
That's unacceptable, it has to be fixed by Toyota. Leaving the window down even a little bit makes the car a more inviting target for a break-in.
Sport-Tech is offline   Reply With Quote
Old 04-18-2014, 11:13 PM   #14
Nicky
Nicky's Avatar
Drives: '05 Acura TSX, '14 FRS (Asphalt)
"just a thought."?!?
More like just the solution! This fixed it for me.. thank you!
Out of curiosity I wonder how that switch works. It only works with the screw tightened versus loose?
Nicky is offline   Reply With Quote
*Auto* Light from windows flash on driver's door Walla Walla Issues | Warranty | Recalls / TSB 7 12-05-2013 12:09 PM
Remotely Open Windows with Keyfob Sportsguy83 Electronics | Audio | NAV | Infotainment 20 05-14-2013 10:19 AM
18x8 Drag DR 38 +35 Never opened Tdooley Wheels and Tires 2 02-09-2013 11:42 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
Door Open Buzzer cmspooner Cosmetic Modification (Interior/Exterior/Lighting) 5 08-13-2012 10:20 AM
