Old 07-23-2012, 11:29 PM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Remotely Open Windows with Keyfob
Thanks to @thorlius, the same guy who invented the now famous TapTurn, also sells a product that apparently is universal and should fit our cars.
Here is the link. AutoWindow
Here is a link to buy: Order Page
The basic one is the one that only lowers and rises windows.
Anyone interested, thoughts, would you think it fits our cars?
Old 07-24-2012, 12:04 AM   #2
DIE1000DEATHS
TechNINJA
DIE1000DEATHS's Avatar
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
Tap turn thread about that talks about this. But my comment from there...
Never had this on a vehicle, but am definitely GOING TO!. As far as his window modules, they look to integrate to the German cars only. Otherwise he utilizes DEI (known for owning Viper, Python, etc...) 530T window automation modules. This would require a bit more work than most people are probably comfortable with... I have installed these on all my vehicles to remotely roll up or down the windows, as well as using Field Disturbance, or Mass Sensors, to be able to arm the car with the windows down and roll them up when someone gets too close.
DIE1000DEATHS is offline   Reply With Quote
Old 07-24-2012, 01:16 AM   #3
Sportsguy83
Drives: Limited BRZ
Yes, I was the one on the thread that pointed out that aside from Tapturn, this was also a product on the site. I just wanted to make a new thread and keet the discussions separate and avoid this...
From that thread post #16:
Originally Posted by sportsguy83 View Post
It seems he also sells other hardware to remotely lower the windows. A lot of people are interested in that too. Good find OP.
So, how much work is needed? soldering, cable routing, have any idea where it needs to tap on our cars?
Old 07-24-2012, 11:42 AM   #4
DIE1000DEATHS
TechNINJA
Sorry, my intention was not to thread jack.. Window modules require connection in the door, at the motor. You need a healthy power feed for the module, and then run wiring into each door. The reason is that you have to catch the wiring between each switch and motor.
Old 07-27-2012, 07:15 AM   #5
Sportsguy83
Drives: Limited BRZ
Don't worry, you did not thread jack. I meant to say I did not want to jack in the other thread. /i guess I won't be adding this, unless you travel here and install it hahaha
Old 07-27-2012, 03:30 PM   #6
DIE1000DEATHS
TechNINJA
Could be a great excuse for a road trip! LMAO I'll be doing mine soon, just getting all my parts together. It will be tied into my aftermarket alarm/start. I haven't looked at the door wiring boots yet, so I'm not sure the difficulty there. Unfortunately many new cars use plugs at the door and the body, which requires drilling out pin locations to fish wiring through. I've only owned one car that needed that so far, and it was hell.
Old 11-18-2012, 02:15 PM   #7
iBRZ
fanboy
iBRZ's Avatar
Drives: SWP Limited BRZ AT
I'd love to resurrect this thread. Did anyone ever do this mod?
iBRZ is offline   Reply With Quote
Old 04-10-2013, 11:08 PM   #8
MaximaZero
MaximaZero's Avatar
...I take the silence as a no?
MaximaZero is offline   Reply With Quote
Old 04-10-2013, 11:23 PM   #9
husker741
This was one of the best features on my Lexus. Great to get rid of the hot air before I get to the car.
husker741 is offline   Reply With Quote
Old 04-11-2013, 09:10 AM   #10
xjohnx
Grip>Slip
xjohnx's Avatar
A couple guys were exploring the possibilities with @scottmcphee on this thread http://www.ft86club.com/forums/showthread.php?t=25442
Old 04-11-2013, 10:32 AM   #11
spgrizz22
Drives: Scion FR-S
Don't do it. I was going to get it done with my Viper 5904 system but they said if I install or they install it, it will blow the motor within a year. They even called scion.
spgrizz22 is offline   Reply With Quote
Old 04-11-2013, 12:48 PM   #12
Sportsguy83
Drives: Limited BRZ
Troll? Sarcasm? Late April fool's joke?
Old 04-12-2013, 10:38 PM   #13
scottmcphee
scottmcphee's Avatar
Drives: 06 Subaru Legacy
I don't get why. The DEI530T module has over-current cut out protection... In other words when it is sensing that too much power is required while driving a window up or down it assumes an obstacle or end of travel has been reached or something is binding, and it cuts power. This is to prevent burnout. This might actually be smarter than the stock window control in the car, which may be oblivious to over-draw and depends on you to lift finger off the switch to cut power. If the scion guys fear burnout it suggests they know the car does not have over-current protection.
Quick test is grab the window while it's rolling up with enough force to stop it mid tracks while holding the button up. It will take mighty force to stop it but will not break anything in doing so... Do this while never letting go of holding the up button. And see if the window continues to fight you going up, or gives up and goes slack - stops trying. Repeat this test using DEI one touch up feature, and it will go slack very quickly after window comes to rest.
I don't know if the viper 5904 is the same as dei530T.
scottmcphee is offline   Reply With Quote
Old 04-13-2013, 05:42 PM   #14
DIE1000DEATHS
TechNINJA
TROOF. As DEI calls it, the unit measures "AC noise". There are 4 settings for basically different levels of current draw. Low / Factory / Medium / High. They can vary between different cars as far as what you need the setting to be on.
I've been slacking on my install of my Alarm/RS combo, so I haven't installed it yet, and was contemplating it anyway. On my last car I had it set on "HIGH" and in the winter when the temps added challenge to the motors, my windows would sometimes not roll all the way up without a few presses of the switch :/
They absolutely will not cause a premature failure of your window motor, and will not cut off limbs if one is caught in the windows path hahahahaha.
For reference, the 5904 is an alarm/keyless/remote start 2-way system from Viper. The 530t is the window automation module.
For the record: I've done these on my last 3 vehicles, and several others.... I was an installer for a car audio shop for 8 years.
Pockmarks on windows? Dang Lad Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 20 09-27-2012 03:52 PM
Remotely lower windows with key fob? Kido1986 BRZ First-Gen (2012+) — General Topics 25 07-16-2012 10:11 PM
Tinted Windows koolhawk CANADA 20 06-19-2012 07:27 PM
Keyfob same as Toyota Prius, guise! dookie11 BRZ First-Gen (2012+) — General Topics 18 05-31-2012 04:49 PM
Windows 7 Theme ToyotaObsession Scion FR-S / Toyota 86 GT86 General Forum 0 05-28-2011 03:27 AM
