| CANADA Canada |
Drives: WRB BRZ
Side markers laws (one on the front wheel arches)
Hi,
Anyone know if it is legal to have the JDM clear lens on the side markers (instead of the amber one we get) here in BC? I heard some mix messages, some say it have to reflect amber but looks clear, some say it have to light up amber while other says it can be a white light. I was looking at the BC Laws website: http://www.bclaws.ca/EPLibraries/bcl...ml#section4.01 Under section 4.12-1a, it seems to suggest that I can change both the lens and the bulb to white. Anyone cares to comment? Thanks! |
Drives: 2013 SUBARU SWP BRZ
I've had them since July, and i've driven by cops with no problems so far!
Drives: WRB BRZ
#5 | |
Drives: BRZ!
Reflective devices
4.21 (1) A vehicle must be equipped with at least one red reflector at the rear of the vehicle, either separate or incorporated into a tail lamp, that is mounted at a height of not less than 38 cm and not more than 1.83 m. (2) Subsection (1) does not apply to a vehicle manufactured before January 1, 1958. (3) Only amber reflectors may be mounted on the front or side of a vehicle. (4) Only red reflectors may be mounted on the rear of a vehicle or on the side of the vehicle at or toward the rear of the vehicle. Source Its the same here in Quebec, got 2 tickets with JDM cars in the past... but MOST cops don't look at this... Only the ones that know their stuff with mods...
Drives: WRB BRZ
That's the part that I'm confused about... Would you say it's a "Reflector" or "Side Marker Lamp"... Since it lights up (not just a reflector that gives off no light on it's own) I tend to think it's a side marker... according to the link I sent at the first post...
4.12 (1) A vehicle may be equipped with (a) 2 side-marker lamps, mounted on each side of the vehicle near the front, that are capable of displaying only white or amber light, and (b) 2 side-marker lamps, mounted on each side of the vehicle near the rear, that are capable of displaying only amber or red light. (2) The side-marker lamps referred to in subsection (1) may operate in conjunction with turn signal lamps or the hazard warning signal. (3) A vehicle with an overall width of 2.05 m or more, or having a gross weight in excess of 1 400 kg, may be equipped with side-marker lamps mounted on each side of the vehicle at the horizontal mid-point of the vehicle. [en. B.C. Reg. 476/98, s. 2.] |
Drives: White FR-S
The wording makes it sound like having a reflector is entirely optional. Maybe consider painting it body colour?
Drives: 2013 FR-S (Raven Black)
Anyone have an answer on this for Ontario?
Drives: Subaru BRZ
Bryan.
#10 |
ONTARIO
"Lamps... ...Side marker lamps (13) When on a highway at any time from one-half hour before sunset to one half-hour after sunrise and at any other time when, due to insufficient light or unfavourable atmospheric conditions, persons and vehicles on the highway are not clearly discernible at a distance of 150 metres or less, every motor vehicle or combination of vehicles having a length in excess of 6.1 metres shall carry not fewer than four lighted side marker lamps, one of which shall be located on each side of the vehicle or combination of vehicles near the front and shall display a green or amber light and one of which shall be located on each side of the vehicle or combination of vehicles near the rear and shall display a red light and each of which lights shall be visible for a distance of 150 metres from the side of the vehicle or combination of vehicles upon which it is located; provided that a vehicle or combination of vehicles may carry four reflectors approved by the Ministry instead of the side marker lamps required by this section; and provided further that, if the clearance lamps upon the left side of any vehicle or combination of vehicles display lights visible for a distance of 150 metres from the left side of the vehicle or combination of vehicles, it is not necessary to carry side marker lamps as required by this subsection on the left side of the vehicle. R.S.O. 1990, c. H.8, s. 62 (13)." Green?!?! Seriously?!?!? Bwa Hahahahahaha!!! Guess I'll take my chances with amber bulbs in my JDM black crystal Lamp assemblies. |
#11 |
Drives: 1991 Acura NSX, 2013 Scion FRS
You can have the clear side markers just make sure you have a Amber bulb in there.
Just take a look at some cars in Ontario that come like that from factory. ei. 2008 Toyota Yaris But even if you were going to be a bad boy and do something else yer not gonna get pulled over for it. My wife's Yaris came with clear side markers and amber bulbs fromt eh factory. On my S2000 I replaced the amber markers with clears jdm ones and amber bulbs. In my sig below you can see my NSX. I painted over my amber markers at the front corners and rear red ones.
1991 BB NSX . 2013 WO FRS . 1978 Yamaha SR500
#12 |
Drives: Monster Green 2013 Scion FR-S
I have mine blacked out an not had any trubles
#13 | |
Drives: 04 is300 sport design ii
#14 |
Drives: SOLD...
Yup my Yaris has clear side markers, with amber bulbs from factory.
Think you would be fine with an amber bulb.
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018 and its gone... Sept '18 tho I am sure I will miss it Replaced with 18 50th edition ND ![]() |
| WTB side markers | Asphaltfrs1 | Exterior Parts (Aero, Lighting, Etc.) | 9 | 01-21-2013 06:30 AM |
| Smoked Front Side Markers | White64Goat | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 12-20-2012 01:50 PM |
| WTB Clear Side Markers | Sportsguy83 | Exterior Parts (Aero, Lighting, Etc.) | 2 | 11-15-2012 03:55 PM |
| WTB: Stock Amber Front Side Markers | JWMotoring | Exterior Parts (Aero, Lighting, Etc.) | 0 | 11-06-2012 05:15 PM |
| FR-S / BRZ side markers interchangeable? | Slant | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 06-30-2012 07:26 PM |
