Old 01-16-2013, 01:10 AM   #1
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Shift position indicator not shown in Manual
I just took delivery of my FRS last week. I recently read the manual about turning ON the Shift-up indicator (pg 152 in the owner's manual) and after turning it on, I still don't see anything. I don't see the gear # indicator nor do I see any upshift indicator. Anybody else have this problem? I don't think it's a big deal since I think intuitively I know when to shift for max fuel efficiency, but I want to know if there's anything wrong with my FRS.
mit_peid is offline   Reply With Quote
Old 01-16-2013, 01:16 AM   #2
congiiee
Drives: WRB Subaru BRZ
heres video. watch the whole thing. The dude explains how to turn the shift indicator on.
[ame="http://www.youtube.com/watch?v=fB9dcC9dl3w"]Scion FR-S: How to set the Shift Light & Gear Indicator Display Settings (BRZ GT86) - YouTube[/ame]
congiiee is offline   Reply With Quote
Old 01-16-2013, 01:24 AM   #3
mit_peid
Boosted Noob
mit_peid's Avatar
But I did set it to "G-on" and still I don't see the display for my gear. Do I need to set my rev-limiter light limit first? (Cause I haven't done that yet, still breaking in my car).
Old 01-16-2013, 01:51 AM   #4
mit_peid
Boosted Noob
mit_peid's Avatar
So all you guys with the stick can set it to "G-on" and see what gear you're in digitally? Does the engine need to be on? What if its in ACC and you're in a gear physically? I ask because I don't see anything where there should be a R, 1, 2, 3, 4, 5, or 6. Now I feel I need to bring it into the dealer for warranty service.
Old 01-16-2013, 08:45 AM   #5
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
The car needs to be running, in gear with the clutch out.
Apoc is offline   Reply With Quote
Old 01-16-2013, 09:04 AM   #6
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Being that it doesn't have switches at each gear placement. I assume its calculating what gear its in based upon rpm and mph. Similar to gear indicators you can put on motorcycles.
Therefore the car has to be moving or at least the wheels turning. If you notice it takes it a split second or so to update when you change the gears and blanks when you depress the clutch.
FRSFirestorm is offline   Reply With Quote
Old 01-16-2013, 09:07 AM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
This.
Car has to be running, in gear, clutch out, and moving for it to show. Unless you put it in reverse. Then the R appears immediately (reverse position sensor tips the cluster off).
Old 01-16-2013, 10:46 AM   #8
Realm
Drives: Scion FR-S
Don't start the car, just the ignition needs to be turned on... I was pulling my hair out with this initially lol
Realm is offline   Reply With Quote
Old 01-16-2013, 12:09 PM   #9
mit_peid
Boosted Noob
mit_peid's Avatar
Thanks all. It actually works. I wasn't expecting what seems like a bit of lag, but probably more caused by me not completely being off the clutch when I'm in gear initially. I don't like admitting this, but I was having a hard time sleeping last night cause of this (dreading bringing the FRS in for warranty, and receiving a f'ing Corolla for a rental while I wait for it to get fixed).
Old 11-22-2017, 02:20 PM   #10
yackery
yackery's Avatar
Drives: 2017 Series Yellow BRZ (manual)
BRZ Ltd Update for GSI Toggle
If you have steering wheel Multi-Information Display Control Switches, navigate to the Gear Shift Indicator toggle display with two presses of the right arrowhead.
This is explained in your 2017 manual pp 213,214, and 223.
I was unable to cycle out of ODO/TripA/TripB with the (km/h-MPH) and ODO/TRIP dash switches.
yackery is offline   Reply With Quote
Old 11-22-2017, 03:37 PM   #11
bababooey
Drives: BRZ SWP Limited -6MT
welcome to the club. old thread tho
Old 11-22-2017, 04:03 PM   #12
Hey, they get points for not starting a new one when on topic (updated) in an existing one!
Old 11-22-2017, 04:52 PM   #13
bababooey
you're right, cant win around here.
another one them boring days
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 08:42 PM
Manual shift in local traffic? A soon-to-be FRS owner doctortt Scion FR-S / Toyota 86 GT86 General Forum 38 01-15-2013 11:28 PM
FT86 GT manual gear indicator KamalT Engine, Exhaust, Transmission 3 10-04-2012 09:43 PM
what does the rpm shift indicator beep sound like? pr086 Scion FR-S / Toyota 86 GT86 General Forum 10 07-26-2012 01:28 AM
Headrest position Sigh-on-Rice Scion FR-S / Toyota 86 GT86 General Forum 2 06-15-2012 01:28 PM
