Old 08-22-2012, 10:38 PM   #1
W2
W2's Avatar
Drives: Firestorm FR-S
Airaid Intake Install with Snorkel Delete DIY
So my Airaid intake came in today and of course I had to throw it on ASAP. I am pleased to say everything was packaged very well with the hardware separated individually in the bag. The instructions were spot on but I have included a few things below I think would help with the install. I also have highlighted removing the snorkel behind the front fender without actually removing the entire fender.
Stock Removal
First up was removing the stock intake. In the picture below remove the 3 bolts circled in green. They require a 10mm socket and the top right one is hidden down behind the air filer box. Next loosen the 3 clamps circled in blue and remove each section/tube. The whole stock assembly should easily lift out now.
Snorkel Removal
Next up is removing the snorkel without taking off the front fender. You are at your own risk with this, I am not responsible if you screw up. This requires some patience and smaller hands wouldn't hurt. Start by removing the 5 bolts circled in yellow below and the two pop clips circled in blue. The metal strip with rubber seal will lift off, sit this to the side.
Now you will need to gently pull the fender up and reach in with a 10mm boxed in wrench. There are only 2 bolts you need to remove and you can see them right under the fender. I broke them loose with the wrench then finished removing them by hand. Not too bad but take your time and don't damage the fender.
After the two bolts are removed it is not time to pull the snorkel out. You will need to wiggle it around and orient it in such a way to pull it out between the fender and frame. I found the fender will pull out from around the headlight housing slightly and allow more space to pull the snorkel on thru, see below.
Now put the metal stip back on with the 5 bolts and 2 pop clips. Done.
Airaid
Airaid time! Really the instructions are great so follow them, they are not Chinese garbage like most things nowadays. You need to assemble the air box and use a couple new supplied modified mounts. After that it is pretty much just the opposite of removing the stock unit. Here are some pictures and tips that should help you out.
  1. I cleaned ever thing with a quick wipe down to ensure nothing got into the intake during manufacturing, packaging, etc. I only found cardboard dust from being in the box but it is still good to double check.
  2. Routing the MAF wire. David from Airaid posted something up about this and it is good to double check as it might come to close to the belts with the new routing. See link: http://www.ft86club.com/forums/showp...5&postcount=35
    The clip is wrapped in tape so I gently cut around it to allow removal. I then used some electrical tape to re-wrap the cut out spot.
  3. Finally the instructions hit on removing the sound generator. I also took this out. They include a nice plastic plug for the firewall. Pull the tube out and the rubber grommet, then just push the supplied plug in. Done.
Here is it is all installed, cleans up the engine bay great! Total time was just a hair over an hour while taking pictures. If you can use basic hand tools this is a piece of cake.
Tools used: a 10mm socket wrench with extension, small and large flat head screwdrivers, and a couple allen wrenches for the new Airaid hardware.
See the official Airaid review thread here: http://www.ft86club.com/forums/showthread.php?t=14897
Let me know if you have any questions.
W2 is offline   Reply With Quote
The Following 14 Users Say Thank You to W2 For This Useful Post:
AIRAID (08-23-2012), AJUSA.com (09-04-2012), AsphaltLover (08-24-2012), ATL BRZ (08-23-2012), calis5nest (08-23-2012), cuddefred (10-03-2012), ducks (10-10-2012), Foobar (08-22-2012), Keith@AIRAID (08-23-2012), RandomHero (08-23-2012), SciOnDrifTtSlIdeR (08-31-2013), serial gixxer (08-23-2012), Shipwreck (02-27-2013), terrypm (08-25-2012)
Old 08-22-2012, 11:29 PM   #2
was385
Drives: MT WRB BRZ Limited, 2007 911s
Anyone removed just the snorkel and kept the stock intake? Thoughts about it?
was385 is offline   Reply With Quote
Old 08-23-2012, 02:02 AM   #3
calis5nest
calis5nest's Avatar
Drives: scion frs firestorm
Thanks for posting very helpful
-Alan
calis5nest is offline   Reply With Quote
Old 08-23-2012, 01:37 PM   #4
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 08-23-2012, 01:39 PM   #5
Keith@AIRAID
Drives: 51 Kaiser, 97 4Runner, 07 Civic Si
You will lose power doing this, as it leaves a sharp edge for the air to fight when entering the stock airbox. That's why our cold air box has a velocity stack at the inlet to smooth the airflow entering the box. I proved this on the flowbench and the dyno in development.
Keith@AIRAID is offline   Reply With Quote
The Following 3 Users Say Thank You to Keith@AIRAID For This Useful Post:
AJUSA.com (09-04-2012), quality_sound (10-29-2014), SkAsphalt (08-23-2012)
Old 08-23-2012, 01:47 PM   #6
FR-S,M.D.
Drives: 2013 Argento Scion FR-S 6AT
What's the purpose of the snorkel?
FR-S,M.D. is offline   Reply With Quote
Old 08-23-2012, 01:55 PM   #7
GregV
Drives: Kia Stinger GT2
It's what pipes the intake noise into the cabin.
GregV is offline   Reply With Quote
Old 08-23-2012, 02:06 PM   #8
was385
Wrong tube. That comes off the intake, the snorkel draws air in to the intake
Old 08-23-2012, 02:07 PM   #9
was385
Good to know, thanks.
Old 08-23-2012, 02:15 PM   #10
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Yeah looks like alot of extra work only to lose power ??
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 08-23-2012, 02:54 PM   #11
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
Taking the snorkel off the stock intake will lose power yes but it has been noted by several people and several manufacturers that the removal of this snorkel (the tube in the bumper) for an aftermarket inatake will net slight power gains and has even been said to sound better
RandomHero is offline   Reply With Quote
The Following User Says Thank You to RandomHero For This Useful Post:
Old 08-23-2012, 04:44 PM   #12
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Ahh reread the thread, powerloss on stock intake
Good to know! Thanks
2URGSE
Old 08-24-2012, 05:01 AM   #13
AsphaltLover
AsphaltLover's Avatar
Drives: 2006 Scion TC, 2013 FR-S Asphalt
worked like a charm. The snorkel closest to the driver side headlight finally popped loose when i pushed it towards the other headlight and twisted it counter clockwise.
Took an extra 15m to take out along with the sound generator. took a bit longer till I remembered to pull out the grommet from the firewall.
AsphaltLover is offline   Reply With Quote
Old 08-31-2012, 07:04 PM   #14
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Wow I can't believe how much of a fight that snorkel put up. Thanks to my opposing thumbs and a pair of plastic cutters, I won the battle.
It was too risky to me to just try to pull it out. I could see where it was getting caught up and it wasn't pretty. Needless to say I won't be going back to a stock intake....
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Official AIRAID Intake System Feedback, Pictures Thread AIRAID Engine, Exhaust, Transmission 525 08-17-2014 05:20 AM
xcelir8brz's Stock Intake Tube Rubber Delete xcelir8brz DIY (Do-It-Yourself) Guides 99 04-10-2014 12:44 AM
AIRAID FR-S / BRZ Cold Air Intake system Sneak Peak / Development Information AIRAID Engine, Exhaust, Transmission 396 10-04-2012 08:27 AM
Airaid Intake System Official GB - The pre-order AJUSA.com Engine, Exhaust, Bolt-Ons 212 09-19-2012 07:36 PM
