Old 01-13-2013, 12:59 PM   #1
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Exclamation Wanting a Slight Drop without Voiding the Warranty**
hey guys so im getting aftermarket Miro 111s 18 inch wheels staggered setup in the next two months.... the car is going to sit a little high for my taste as i have seen on pictures so i was thinking about doing a slight drop with some springs. im not looking to track the car at all just street racing on the way home on the highway haha. im pretty sure that if i replace the springs then the whole warranty with the suspension will be voided but i could always replace the stock springs and bring it into the dealer to get fixed if anything happens. What springs would you guys reccommend that are durable and have a good reputation, looking for about an inch drop nothing more than that.
Also if anyone has any reccomendations on the warranty or info of what to do if anything happens to the suspension please let me know because that is my main concern !!! *** THANKS !
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 01-13-2013, 01:24 PM   #2
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
Find a dealership that will install springs for you. It will cost a lot compared to a local speed shop, or doing it yourself but then they would warranty the work. Im sure there are dealerships out there that would do a TRD spring for you no problem.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 01-13-2013, 02:15 PM   #3
ScionFR-S
ScionFR-S's Avatar
So i should go to a Toyota Dealership and ask for TRD springs that would keep the warranty?
maybe the ones they put on the five axis body kit
Old 01-13-2013, 02:18 PM   #4
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
TRD springs are only a .6" drop FWIW. And your warranty for the suspension would only be voided if their is a problem that comes up due to the part.
ZC6BRZ is offline   Reply With Quote
The Following User Says Thank You to ZC6BRZ For This Useful Post:
SkAsphalt (01-13-2013)
Old 01-13-2013, 05:26 PM   #5
Superhatch
AIM4APX
Superhatch's Avatar
Correct, so if you say install them yourself and mess up a seal and then blow a strut you would be out of luck.
Really, with a drop the only warranty part would likely ever go bad would be a strut. To date I think the only strut failures have been from improper install. But, keep in mind that you will likely reduce the life of the OEM strut if you put a lowering spring on it. What that life reduction is, is currently unknown. I'd say it's usually cut in half.
Old 01-13-2013, 06:23 PM   #6
ScionFR-S
ScionFR-S's Avatar
Could you guys give me a link to some good springs , what would I need for the install bc I know they sell the springs only or springs and camber plates etc
Old 01-13-2013, 09:10 PM   #7
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
You'd need springs only basically. Some come with bumpstops, some require you to cut the stock ones.
I recommend RCE yellows. However any/all springs are going to be fine if all you care about is the car being lower. If you care about performance, its a slightly different story.
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 01-13-2013, 10:28 PM   #8
ScionFR-S
ScionFR-S's Avatar
so if my rear strut goes out how would i know and i could just get an aftermarket strut rather than going to the dealer and putting on another OEM one.... could i go to the dealer and ask them to tell me whats wrong if it so happens ?
and just regular RCE Yellow Springs i would get, i know they come with bump stops which i have no clue what that is lol
Old 01-14-2013, 02:32 PM   #9
Superhatch
AIM4APX
Superhatch's Avatar
If I were you I would start reading through some suspension basics before ordering springs.
I could answer your questions, but I think you need to absorb that information and understand the system prior to ordering because different springs will make the car feel differently. Hop into the suspension forums and start reading everything you can.
Eibach and RCE seem to be the two most commonly purchased atm, but TRD or STI are also options but more expensive.
drop, miro 111, rce yellow, suspension
Slight drop, world of difference. WheelDude.com FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 11-21-2014 05:05 PM
Car randomly doesn't start on slight hill Craig Issues | Warranty | Recalls / TSB 7 02-01-2013 01:48 PM
Slight grinding from the brakes... kndonlee Other Vehicles & General Automotive Discussions 7 09-15-2012 05:14 PM
wanting to buy a TRD rear spoiler whyreeto Australia Classifieds 6 09-09-2012 02:40 AM
Am i crazy for not wanting mrlewistan Scion FR-S / Toyota 86 GT86 General Forum 27 08-21-2012 07:45 PM
