Old 01-10-2013, 03:57 PM   #1
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
question about window tinting
when the tint is first applied, the shop usually tells you do not roll the window for couple of days. but for the brz/frs, you know when you open and close the door the window automatically rolls a bit. how should we do about that?
chenshuo is offline   Reply With Quote
Old 01-10-2013, 03:59 PM   #2
i_4got
i_4got's Avatar
Drives: Whiteout FR-S
Not sure if it's standard, but this is how the shop that did mine went about it:
They basically left that top "border" of the window pane untinted. So the very top portion of the window that goes in and out of the rubber seal is left untinted. That left the top "safe", but I was still worried about the bottom of the window since it's still being rubbed when the door opens and closes. I just tried to avoid driving my car for 2 days, and there seems to be no rubbing or scrapes on the bottom at all.
i_4got is offline   Reply With Quote
Old 01-10-2013, 04:00 PM   #3
L3P47
L3P47's Avatar
Drives: Firestorm FR-S
The window only moves about a 1/2- 3/4 of an inch at most. I thinl it should be fince considering it's only a small amount. If your paranoid about it though I would just let it set for a couple days.
L3P47 is offline   Reply With Quote
Old 01-10-2013, 04:01 PM   #4
leon78
leon78's Avatar
Drives: 13 Whiteout
Just got mine done....guy said to open the doors as little as posible for a 24hrs. No big deal.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 01-10-2013, 05:07 PM   #5
obriennathaniel
obriennathaniel's Avatar
Drives: Satin White Pearl Limited BRZ
yea alot of coupes do that, its no big deal. unless they did a shitty job, i wouldnt worry about it. i had zero issues with mine, i have 5 all the way around and 50 on my windshield.
obriennathaniel is offline   Reply With Quote
Old 01-10-2013, 05:12 PM   #6
Kevin@RAD
Kevin@RAD's Avatar
Drives: Infiniti G35X
As long as the tinter knows what he's doing, you'll be okay.
Kevin@RAD is offline   Reply With Quote
Old 01-10-2013, 05:23 PM   #7
Foobar
SLO NO MO
Foobar's Avatar
Mine hit it with a heat gun to ensure a proper adhesion and suggested I just don't roll them down for a few days and keep it parked in sunlight. The auto down on open was not a concern for him at all.
If you're really concerned, you can disable the door open switch.
Sent from my Galaxy Nexus using Tapatalk 2
Old 01-10-2013, 05:27 PM   #8
tbwoodlee
I Void Warranties
tbwoodlee's Avatar
Drives: Asphalt 86
My guy tinted all the way to the top, and I drove the hell out of my car the following days. The door window went up and down probably over 100 times. It made no difference at all on the final result of my window tint. It looks great.
tbwoodlee is offline   Reply With Quote
Old 01-10-2013, 05:51 PM   #9
Hardrock4445
Hardrock4445's Avatar
I wouldn't want the window only tinted 98%, if the guy knows what he is doing you will be fine. If you are still worried pull power window fuse or relay. Easy
Hardrock4445 is offline   Reply With Quote
Old 01-10-2013, 07:26 PM   #10
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
What do you mean by disable the door open switch? does the window not go down when you open the door or something?
Old 01-10-2013, 07:39 PM   #11
Foobar
SLO NO MO
Foobar's Avatar
If you disable the push switch that gets triggered when the door opens either by pulling the fuse or by doing one of the DIY fixes mentioned on these forums, your window will stay up when you open the door.
This has the side effect, however, of not turning on the dome light or triggering the security system as well, so you have that to deal with.
Old 01-10-2013, 08:08 PM   #12
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Will take cause damage to the window? will it trip up when i open the door? I mean if there's no damage then why doesn't the manufacture build it to not automatically roll down in the first place?
Old 01-10-2013, 09:28 PM   #13
Foobar
SLO NO MO
Foobar's Avatar
They built it to go down a crack to prevent a build up of pressure when you close the door. It makes it easier to close the door and it eliminates any ear popping type situation when a door is closed.
As far as I know, this doesn't damage the window.
Old 01-12-2013, 10:58 PM   #14
Hardrock4445
I believe that is the job of the vents in trunk. the window auto down/up when opening and closing the doors is to help extend the life of the door weatherstripping.
NW Tint Shop Directory DarrenDriven Northwest 102 04-17-2018 09:10 PM
Window tinting Sydney Nytemayr AUSTRALIA 5 01-18-2013 11:46 PM
Window tinting in states that do not allow it CaptainSlow Cosmetic Modification (Interior/Exterior/Lighting) 10 10-31-2012 01:30 AM
Window Tinting - Interference jpit Cosmetic Modification (Interior/Exterior/Lighting) 0 09-01-2012 06:54 PM
Charlotte NC window tinting Thongpocket BRZ First-Gen (2012+) — General Topics 1 06-28-2012 12:38 PM
