Old 01-03-2013, 10:10 PM   #1
corvino26
corvino26's Avatar
Drives: 2013 Scion FR-S 6MT Raven
HID Relay needed?
I purchased an HID kit less then a month ago. Product has a 2 year warranty on it. Apparently burned a ballast. I am interested to know if I need an HID relay. Any thoughts or advice would be greatly appreciated. Thanks in advance!
corvino26 is offline   Reply With Quote
Old 01-03-2013, 10:14 PM   #2
corvino26
corvino26's Avatar
or even a canbus or harness... not really too sure amongst the difference but still need a solution to prevent further damage or faulting
Old 01-03-2013, 10:45 PM   #3
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
i dont think u need a relay on HID. probably low quality ballast? thats the 1st time i heard burning of ballast. somebody told me that if u plug the HID on correct polarity since toyota cars needs to be reverse polarity, u would blow up ur lighting fuse.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 01-03-2013, 10:50 PM   #4
empower-auto
Kouki-Monster
empower-auto's Avatar
you buy a shitty DDMtuning kit or what?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 01-03-2013, 10:58 PM   #5
i_4got
i_4got's Avatar
Drives: Whiteout FR-S
Someone else on the forums got a faulty ballast from a vendor and just got it replaced (under warranty from the seller). I'm thinking you're having the same problem. What happens when you try to turn on the headlights? Does one side flicker and then just not turn on?
i_4got is offline   Reply With Quote
Old 01-03-2013, 11:33 PM   #6
corvino26
corvino26's Avatar
its an autovision 35w kit and the passenger side ballast does not flicker or do anything and the driver side turns on and stays solid with no flickering.
Old 01-03-2013, 11:36 PM   #7
i_4got
i_4got's Avatar
Has the HID on the faulty side ever worked? It could be the reverse polarity issue. Try flipping it around.
Old 01-03-2013, 11:37 PM   #8
corvino26
corvino26's Avatar
it worked just fine for 3 weeks then just suddenly stopped working today
Old 01-04-2013, 12:34 AM   #9
whataboutbob
AutoX-10/10ths every run
No need for a relay on the HIDs I bought from @KI_ZN6 a.k.a. HID_Powerhouse.
Build thread:Here
Old 01-04-2013, 02:26 AM   #10
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Haven't heard of Autovision, is it the digital slim ballasts? It just sounds like a bad ballast to me, it happens even with the more expensive German kits. Get a replacement and you should be fine. If you're really worried about the relays, you can get a complete new kit from one of the vendors here on the forums - they're all high quality kits with no need for a relay, plus a lot of us have already bought and tried the vendor kits so you know they'll work w/o relay.
cdo221 is offline   Reply With Quote
Old 01-04-2013, 08:31 AM   #11
i_4got
i_4got's Avatar
Same here. If you need to buy a replacement, I'd highly recommend buying from Ken @KI_ZN6. If you have any issues, he'll take care of you.
Old 01-04-2013, 07:26 PM   #12
KI_ZN6
KI_ZN6's Avatar
Our HID kits do not require running any relay harnesses. Relay harnesses are commonly used for vehicles that utilize high/low beam headlight setups or if there are wire modifications to the headlights.
KI_ZN6 is offline   Reply With Quote
Old 01-04-2013, 09:16 PM   #13
Dezoris
Dezoris's Avatar
If you have warrnty issues and have to buy new go with Ken from hidpowerhouse.
Should have no drama.
Blinker/Hazard Relay Location EmilGH Cosmetic Modification (Interior/Exterior/Lighting) 12 09-10-2015 01:20 PM
LED lighting upgrade and Flasher Relay. jadewbj Cosmetic Modification (Interior/Exterior/Lighting) 20 07-22-2013 08:44 PM
Relay Sound Coming From Passenger Side jjkerr626 Issues | Warranty | Recalls / TSB 0 10-06-2012 10:29 AM
Delete driver01 Canada Classifieds 0 09-21-2012 02:52 PM
Internet Relay Chat (IRC) Channel Sony Off-Topic Lounge [WARNING: NO POLITICS] 10 11-03-2011 10:36 PM
