Old 01-03-2013, 10:39 AM   #1
2forme
Battery problems
Anyone have an issue with the stock battery? Mine apparently doesn't want to hold a charge past two days now....
Could just be a dud. Was curious if anyone had any problems with them.
Old 01-03-2013, 10:44 AM   #2
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Done any recent car audio ? I had a inline capacitor installed on my previous car and I had to use a trickle charger every few days due to the contant draw on the battery
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 01-03-2013, 10:45 AM   #3
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Any aftermarket stuff added?
Tested load while car is off? Values?
CircuitJerk is offline   Reply With Quote
Old 01-03-2013, 10:47 AM   #4
2forme
Dead lol. I've had aftermarket stuff added, but I've moved it to my other car, and worked fine for a couple weeks.
Old 01-03-2013, 02:11 PM   #5
frs23
frs23's Avatar
Drives: FR-S H Lava
"Dead?" What do you mean by that?
Did you check the impedance of the load the battery is seeing when car is off?
(Disconnect one battery terminal and use Ohm setting on voltmeter on + and - cable)
frs23 is offline   Reply With Quote
Old 01-03-2013, 03:11 PM   #6
2forme
Haven't taken a multimeter to it, just noticed the car needing a jump after sitting a couple days. I'll look more into it.
Old 01-03-2013, 03:37 PM   #7
whataboutbob
AutoX-10/10ths every run
Without knowing what you've added it may be hard for us to help you.
My 1st guess is someone wired something so that it didn't turn off with the ignition like it was supposed to...
Build thread:Here
Old 01-03-2013, 03:53 PM   #8
gmookher
bad battery or diode in alt...
gmookher is offline   Reply With Quote
Old 01-03-2013, 04:09 PM   #9
Dezoris
Dezoris's Avatar
Its your Android head unit!
Work backwords, unplug anything you have added rule it out.
The OEM Panasonic batteries are solid, rare to have a failure this early on.
Old 01-03-2013, 11:38 PM   #10
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Chris, let me know when you have time, I'll come over and we can pull fuses and hook my Fluke Multimeter up to the car...much more accurate than el-cheapo multimeter from Home Depot. My bet is you have a parasitic draw from your audio gear...maybe your amp's aren't turning off properly. Once a Lead-Acid battery completely dies once, it becomes damaged and doesn't hold a charge well anymore, best course of action is to find the parasitic draw first, fix it and then replace the battery.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 01-03-2013, 11:44 PM   #11
Sony
Sony's Avatar
He has an Android Head Unit and Hertz Crossovers and Amps, as well as a few smaller things.
Old 01-04-2013, 07:03 AM   #12
2forme
I installed my audio gear in my other car for testing, it worked fine. The battery has died once from leaving my dome light on by accident.
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
Lithium Ion Battery Flat Black VW Scion FR-S / Toyota 86 GT86 General Forum 1 11-09-2012 02:23 PM
Battery Options xn7485 Electronics | Audio | NAV | Infotainment 18 11-05-2012 12:28 PM
Battery in the trunk scottman Electronics | Audio | NAV | Infotainment 14 10-06-2012 07:26 PM
