| View Poll Results: Battery Brand | |||
| Optima |
21 | 38.89% |
| Odyssey |
16 | 29.63% |
| Braille |
15 | 27.78% |
| CTEK |
0 | 0% |
| Hawker |
0 | 0% |
| Audio system oriented battery |
2 | 3.70% |
| Voters: 54. You may not vote on this poll | |||
Drives: 1995 Acura Integra GS-R
Battery Options
Just wondering, if not keeping the stock battery, which did you choose?
Asking from the perspective where battery is used to run the engine, not which is best to run an audiophile's sound system. FYI poll's just top results from a google search. Last edited by xn7485; 11-02-2012 at 01:34 AM. |
Drives: SWP BRZ
I voted Braille, but I'm using the Big Crank labelled version although they're the same battery along side with the Deka and a few others I believe. Weighs in at 18.0lbs IIRC and I had it sitting around anyways.
Ever since Interstate purchased Optima their batterys arent as good as before. Your just paying for the name. Unless you have an off roading then theirs no point in buying one unless your trying to save some weight or getting it for the looks. Pretty expensive just for a pretty battery if you ask me.
If you just do some everyday driving/track theirs no need for it. |
KCCO From Canada
Drives: Asphalt FRS
Braille Lithium Ion Batteries 600cca (roughly) at 9lbs = epic win far more than the car requires and really light. but expensive.
Because compromise ®
Drives: Red Herring
Each brand offers many differnt models. If you are polling regarding audio systems I am suggesting type and capacity is more important than brand.
That Guy
Drives: 2013 asphalt FRS MT
Hawker makes odyssey.
Stock will be fine for a dd. Lightness cost money, how light do you want to go? |
Drives: Attitude
Just tried to jump and recharge a Hawker Odyssey PCJ680. Would never want that experience again. They don't stay charged long and don't like being recharged after losing it. Not a daily driver kind of battery in my opinion.
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
I got a Braille B14115 AGM. 11lbs(5.2kgs), have had it in the car for about 2 months now. No problems what so ever. Haven't found the need to use the battery tender/trickle charger either. As long as your not making short trips you should be fine. Daily commute is 20+mins anyway.
Drives: '06 AM V8V Coupe
Don't forget Deka, they make the Brailles (but sell much cheaper).
For a DD car you probably don't want to reduce the battery capacity too much beyond stock, switching to AGM and dropping a little bit of capacity should shave a respectable amount of weight off. |
#10 |
Optima batteries suck. I went through 7 Red Tops in 4 years. Went and purchased a cheap autozone one and haven't had an issue since.
That said, I'm keeping the stock battery until it dies. It handles my stereo without an issue. |
#11 |
turbo FT-86
Drives: ft-86
#12 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
In the summer, run a Lawn and Garden battery. I use them in my WRX that I RallyCross.
#13 | |
Drives: none yet
I'd go with the odyssey if you're looking at a slightly lighter battery with a good amount of reserve and power. if you want super light, the braille looks pretty good for a light battery. like others said, optima isn't what it used to be. |
#14 |
I've run an Odyssey battery in my MR2 for 4 years now, and I bought it used from a guy who probably had it for 2 or 3 years before me. After 4 winters of sitting in cold storage with no trickle charger, it finally lost its ability to hold a charge. I replaced it for a mere $116 shipped. Definitely worth the weight savings and the longevity over a wet cell battery!
I've replaced more Optimas than I want to think about. And dammit, the BMW I just bought has one in it... grrrr. Unless you're trying to run a ridiculous sound system, don't get an Optima.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
| Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 12:53 PM |
| TR-B1500 battery and billet battery tray install. | mines13 | DIY (Do-It-Yourself) Guides | 8 | 12-07-2012 03:59 PM |
| Canadian FR-S options VS U.S.A's options? | Tino | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-06-2012 10:07 PM |
| Battery in the trunk | scottman | Electronics | Audio | NAV | Infotainment | 14 | 10-06-2012 07:26 PM |
| Gearing Options and Diff options | airboy808 | Engine, Exhaust, Transmission | 26 | 12-25-2011 01:11 PM |
