| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Rx7
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 17x9.0 +38
![]() WORK Emotion Kiwami - 17x9.0 +38mm 5x100 Tires: 225/45 Blizzak Camber: Negative 2.5 now, but will fit with stock cambers Suspension: BC Coil Over, but will work without any spring or coil over upgrade ![]() ![]() ![]() ![]()
#2 |
SLO NO MO
It looked good on the floor of your shop, looks even better on your car!
Really digging the white on white. |
#3 |
Drives: Whiteout FR-S
You would have Works for winter wheels!
#4 |
Drives: Rx7
#5 |
Drives: Rx7
#6 |
Drives: SWP BRZ Limited Manual. 2014
Weight? Also, any other colors?
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|] |
#7 |
Drives: Rx7
#8 |
Pegasus White
Drives: 86
What camber are you running?
Driving: Pegasus White Manual GTS 86.
#9 |
Drives: Rx7
~ negative 2 camber.
#10 |
NW Region Moderator
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels This should be a perfect rear flush fitment!
| The Following User Says Thank You to DarrenDriven For This Useful Post: | Hicklinc (03-23-2017) |
#12 |
Drives: AVO BRZ
Nice!
#13 |
Great Member
Drives: raven, baught 8-29-12, manual
#14 |
Drives: Subaru BRZ
What is largest tire you can run on those without rubbing and zero camber? Would 245/40 fit? The kiwami's are suprisingly concave for a +38 offset! |
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +38 | kimchangil424 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 01-03-2017 06:00 PM |
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +30 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 179 | 11-20-2015 12:12 AM |
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x9.5 +38 | Killerbee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 03-08-2014 04:49 PM |
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x10.5 +32 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 02-25-2014 06:00 AM |
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x7.5 +47 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 08-31-2012 04:17 PM |
