Drives: Scion FR-S, Ultramarine
intake piping + drop-in air filter
Alright so after doing a bit of reading around ive come to the conclusion that buying a drop-in filter and intake piping is better than buying a whole new intake. with that said, i was looking into WORKS' new high-flow filter and zeta's or perrins silicone piping and i was wondering if that would negatively affect anything without me having to get a tune
Drives: Asphalt AT
You shouldn't have to do anything. I will be running the same set up here in a week or so as soon as I get everything from @ZetaPerformance including the radiator kit. I might just reset my ECU after its all put together.
Tune wise might be able to tinker with the higher airflow |
#3 | |
![]() and thanks for the fast reply |
Drives: 86 ZN6
Good choice on the works filter
Let me know when your ready to buy |
Drives: Asphalt FRS
I'm running Zeta Intake and Perrin filter.. I just cannot believe 10hp from a filter so I went with the brand i felt most comfortable with.
Zeta's stuffs top notch, install was a breeze and worth it imo. |
Drives: 2013 BRZ Limited
Installed the Zeta filter on stock set up. Nice change according to my ears and the butt dyno. Awaiting to install the Perrin silicon intake by weeks end.
Addicted
Drives: 2013 Asphalt FR-S 6MT
This setup definitely seems like the best bang for your buck. Any idea how a drop in filter + high flow tube will work with ECUtek stage 2 tune (vs a whole new intake)?
#10 |
good question, hopefully someone more knowledgeable will chime in. I dont see why it wouldnt perform just as good as an entire intake system.
#11 | |
Drives: Whiteout FR-S
I don't have any experience with Injen, AFE, Airraid, etc but would recommend the Perrin tube and filter. I think they offer the majority of the gains you would see with any of those but it's cheaper and super easy to install. |
#12 |
Addicted
If you don't mind me asking why are you not happy with the filter+tube combo?
#13 |
I am happy with it but i am always making changes and trying new parts, i wouldn't recommend it if i couldn't feel a difference. I would recommend it over the AirRaid certainly even if they were the same cost.
| The Best Drop in Air Filter? | FT-86- | Engine, Exhaust, Transmission | 46 | 06-05-2014 07:54 AM |
| Zeta Intake Piping (w/o Sound Generator Outlet) Installed | zkubidu | Engine, Exhaust, Transmission | 3 | 11-16-2012 09:26 PM |
| Cosworth drop in air filter | JoeBoxer | Engine, Exhaust, Transmission | 14 | 08-16-2012 11:20 AM |
| K&N Drop-In Filter for BRZ/FR-S in stock! | Mach V Dan | Engine, Exhaust, Bolt-Ons | 0 | 06-27-2012 02:41 PM |
| Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
