Old 12-28-2012, 10:54 PM   #1
Estey
Drives: Scion FR-S, Ultramarine
intake piping + drop-in air filter
Alright so after doing a bit of reading around ive come to the conclusion that buying a drop-in filter and intake piping is better than buying a whole new intake. with that said, i was looking into WORKS' new high-flow filter and zeta's or perrins silicone piping and i was wondering if that would negatively affect anything without me having to get a tune
Estey is offline   Reply With Quote
Old 12-28-2012, 10:56 PM   #2
Asphalt~86
Drives: Asphalt AT
You shouldn't have to do anything. I will be running the same set up here in a week or so as soon as I get everything from @ZetaPerformance including the radiator kit. I might just reset my ECU after its all put together.
Tune wise might be able to tinker with the higher airflow
Asphalt~86 is offline   Reply With Quote
The Following 4 Users Say Thank You to Asphalt~86 For This Useful Post:
Estey (12-28-2012), oso_25 (01-01-2013), PrDarkKnight (12-28-2012), ZetaPerformance (12-29-2012)
Old 12-28-2012, 10:59 PM   #3
Estey
awesome, just what i wanted to hear
and thanks for the fast reply
Old 12-28-2012, 11:24 PM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Good choice on the works filter
Let me know when your ready to buy
86_ZN6 is offline   Reply With Quote
The Following User Says Thank You to 86_ZN6 For This Useful Post:
Asphalt~86 (12-28-2012)
Old 12-29-2012, 12:51 AM   #5
Estey
lol, im probably going to order the filter from your site tomorrow
Old 12-29-2012, 10:17 AM   #6
Craig
Craig's Avatar
Drives: Asphalt FRS
I'm running Zeta Intake and Perrin filter.. I just cannot believe 10hp from a filter so I went with the brand i felt most comfortable with.
Zeta's stuffs top notch, install was a breeze and worth it imo.
Craig is offline   Reply With Quote
The Following User Says Thank You to Craig For This Useful Post:
Old 12-29-2012, 02:02 PM   #7
ZetaPerformance
ZetaPerformance's Avatar
Thanks for your support!!
ZetaPerformance is offline   Reply With Quote
Old 01-01-2013, 03:40 PM   #8
xcelir8brz
Drives: 2013 BRZ Limited
Installed the Zeta filter on stock set up. Nice change according to my ears and the butt dyno. Awaiting to install the Perrin silicon intake by weeks end.
xcelir8brz is offline   Reply With Quote
The Following User Says Thank You to xcelir8brz For This Useful Post:
ZetaPerformance (01-02-2013)
Old 01-02-2013, 07:57 PM   #9
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
This setup definitely seems like the best bang for your buck. Any idea how a drop in filter + high flow tube will work with ECUtek stage 2 tune (vs a whole new intake)?
l0aded is offline   Reply With Quote
Old 01-02-2013, 08:15 PM   #10
Estey
good question, hopefully someone more knowledgeable will chime in. I dont see why it wouldnt perform just as good as an entire intake system.
Old 01-02-2013, 08:35 PM   #11
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I have the Perrin filter, tube, and FA20 Stage 2 Tune. I like it a lot, i am going to be changing to either the FA20 or Perrin intake soon though but it's not because i'm not happy with it now.
I don't have any experience with Injen, AFE, Airraid, etc but would recommend the Perrin tube and filter. I think they offer the majority of the gains you would see with any of those but it's cheaper and super easy to install.
The Following User Says Thank You to JoeBoxer For This Useful Post:
l0aded (01-02-2013)
Old 01-02-2013, 08:46 PM   #12
l0aded
Addicted
l0aded's Avatar
If you don't mind me asking why are you not happy with the filter+tube combo?
Old 01-02-2013, 08:56 PM   #13
JoeBoxer
JoeBoxer's Avatar
I am happy with it but i am always making changes and trying new parts, i wouldn't recommend it if i couldn't feel a difference. I would recommend it over the AirRaid certainly even if they were the same cost.
l0aded (01-02-2013)
The Best Drop in Air Filter? FT-86- Engine, Exhaust, Transmission 46 06-05-2014 07:54 AM
Zeta Intake Piping (w/o Sound Generator Outlet) Installed zkubidu Engine, Exhaust, Transmission 3 11-16-2012 09:26 PM
Cosworth drop in air filter JoeBoxer Engine, Exhaust, Transmission 14 08-16-2012 11:20 AM
K&N Drop-In Filter for BRZ/FR-S in stock! Mach V Dan Engine, Exhaust, Bolt-Ons 0 06-27-2012 02:41 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
