Old 12-26-2012, 03:49 PM   #1
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
Rod length
Does rod length affect torque output of an engine?
I'll be back!!
F3dzo is offline   Reply With Quote
Old 12-26-2012, 03:54 PM   #2
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
It's not the size of the rod that matters, it's how you use it.
Ravenlokk is offline   Reply With Quote
The Following 3 Users Say Thank You to Ravenlokk For This Useful Post:
Exhaust (12-26-2012), kmbkk (12-26-2012), Tim_Asphalt_FRS (12-27-2012)
Old 12-26-2012, 03:58 PM   #3
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
My rod length is of no concern to anyone but my wife...
That being stated, what matters is overall stroke for TQ output, which would be related to rod length. Longer stroke=more TQ, in theory.
GTB/ZR-1 is offline   Reply With Quote
The Following User Says Thank You to GTB/ZR-1 For This Useful Post:
Old 12-26-2012, 04:05 PM   #4
Pete
Pete's Avatar
Drives: 22 BRZ
The smaller your rod, the more torque you will require everyone to think you have.
Pete is offline   Reply With Quote
The Following 2 Users Say Thank You to Pete For This Useful Post:
Exhaust (12-26-2012), F3dzo (12-26-2012)
Old 12-26-2012, 04:06 PM   #5
lantsalot
Derp
lantsalot's Avatar
So would this imply that (all other engine attributes staying the same) a longer rod would give you a shorter stroke, and thus less TQ?
Edit: I'm using this diagram for my logic. A longer rod would then result in less room for the piston to travel and compress the gas? http://en.wikipedia.org/wiki/File:Ar...e_Zweitakt.gif
lantsalot is offline   Reply With Quote
Old 12-26-2012, 04:39 PM   #6
gmookher
Are you trying to shrink or extend your rod?
gmookher is offline   Reply With Quote
The Following User Says Thank You to gmookher For This Useful Post:
Old 12-26-2012, 04:46 PM   #7
Aetyrno
Drives: 98 Camry
Mounting position of the rod inside the piston is also related. A longer rod which is closer to the surface of the piston can give the same stroke as a shorter rod mounted further from the piston surface with nothing else changed.
This is all talking Honda engines, but it's still relevant to your question:
A longer rod makes more torque with the same piston force, and since it's less angular than a shorter rod, reduces sidewall loading and decreases friction. All of this adds up to more power.
Longer rods also give the pistons more "dwell," the brief periods of time the piston is at top dead center and bottom dead center. A longer dwell allows for better flow of intake and exhaust gases since the piston moves slower between up- and downstrokes.
Read more: http://www.hondatuningmagazine.com/t...d_stroke_ratio
Aetyrno is offline   Reply With Quote
The Following User Says Thank You to Aetyrno For This Useful Post:
lantsalot (12-26-2012)
Old 12-26-2012, 05:08 PM   #8
Bill_Rockoff
Drives: 104kmile FJ1200, 193kmile Maxima
Rod length doesn't have anything to do with the length of the stroke. Crankshaft throw is what determines the stroke.
Bill_Rockoff is offline   Reply With Quote
The Following 4 Users Say Thank You to Bill_Rockoff For This Useful Post:
Exhaust (12-27-2012), Ninjin (12-26-2012), Rayme (12-26-2012), strat61caster (12-26-2012)
Old 12-26-2012, 05:16 PM   #9
strat61caster
strat61caster's Avatar
Go look at an engine assembly; CHANGING ROD LENGTH WILL NOT CHANGE YOUR STROKE. You'll need a new crankshaft to change your stroke length and swept volume. I haven't looked at the dynamics in a long time but you may get a change in compression ratio and the details that Aetyrno went into seem to have some validity.
The only reason to upgrade/change your rods are if you have a new crank and need a new rod to make sure your piston is in the right place as well as stronger rods if your engine is putting out more torque due to other mawds.
Old 12-26-2012, 05:30 PM   #10
Aetyrno
Drives: 98 Camry
Depends which rod we're talking about... if your rod isn't long enough it would make for a short stroke.
Old 12-26-2012, 05:58 PM   #11
whtchocla7e
Drives: 2013 FR-S Hot Lava
Are we all talking about the same rod?
Live to drive another day
whtchocla7e is offline   Reply With Quote
The Following 2 Users Say Thank You to whtchocla7e For This Useful Post:
Exhaust (12-27-2012), F3dzo (12-26-2012)
Old 12-26-2012, 07:01 PM   #12
F3dzo
F3dzo's Avatar
Lmfaooooooo
I'll be back!!
The Following User Says Thank You to F3dzo For This Useful Post:
Old 12-27-2012, 12:37 AM   #13
wrxgoose
WUB WUB
Drives: 2013 Firestorm
such a dirty thread. :p
wrxgoose is offline   Reply With Quote
The Following User Says Thank You to wrxgoose For This Useful Post:
Old 12-27-2012, 01:24 AM   #14
mashal
DADA
mashal's Avatar
Drives: 2013
Wtf lol best thread name ever
mashal is offline   Reply With Quote
The Following 2 Users Say Thank You to mashal For This Useful Post:
Exhaust (12-27-2012), F3dzo (12-27-2012)
Nameless Performance Equal Length Stepped Header Jason@Nameless Engine, Exhaust, Transmission 4525 11-21-2022 05:38 PM
Adjusting The Swing Length of the Door 7thgear Cosmetic Modification (Interior/Exterior/Lighting) 2 11-13-2013 06:40 PM
Length of stock resonator? jm1681 Engine, Exhaust, Transmission 5 10-26-2012 07:25 AM
unequal length headers 001BRZ Engine, Exhaust, Transmission 10 07-21-2012 01:20 AM
AT VS Manuel Based off Life length Xdragonxb0i Engine, Exhaust, Transmission 8 04-26-2012 02:23 AM
