Old 04-25-2012, 12:44 PM   #1
Xdragonxb0i
Drives: ex500r
AT VS Manuel Based off Life length
Its a common fact that Older AT Transmission will go out faster then MT.
Is it still a concern that with spirited driving/track the AT will have to be replaced sooner then the MT.
i have and Avalon (AT) and a tundra (AT), they both hit over 250k on the tranny, but these cars wont get abused like a FRS or BRZ will.
Xdragonxb0i is offline   Reply With Quote
Old 04-25-2012, 12:52 PM   #2
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
You have to do maintenance on MT trannys, so you end up paying to keep that in shape anyway...
There is no way to tell at this point to tell how reliable the trannys are though. One can assume that since its an Aisin box, it should be fairly reliable, but who knows...
- The Ancient BRZ Sacrament
by Zaku
Old 04-25-2012, 01:37 PM   #3
fatoni
It depends on how well Manuel takes care of his car
Old 04-25-2012, 02:22 PM   #4
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
In stock form, I doubt this 200chp motor is going to be stressing either the MT or AT much, even with "spirited" driving. 200 odd crank hp, lower torque, and RWD only is not going to be placing a lot of stress on the transmission and rear diff. I don't see any issue with either lasting 10-20 years, which is how long it's going to take the average driver to reach 200k+.
If I'm wrong, we'll find out in 10 years...
Regards,
Paul Hansen
www.avoturboworld.com
www.facebook.com/BRZSportsCarClub
AVOturboworld is offline   Reply With Quote
Old 04-25-2012, 05:17 PM   #5
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
If you're worried about AT life, put in an aftermarket trans oil cooler.
Old 04-25-2012, 05:18 PM   #6
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
I doubt that will even be required on this car, but let's wait and see.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 04-25-2012, 05:35 PM   #7
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
Some Aisin auto transmissions have failed early. Namely those in VWs and in the Mini Cooper S.
Most of the failures had to do with solenoids, and the "suggestion" of "lifetime ATF."
By 80,000 miles in some cars the AT fluid inside is cooked. So it needs to be changed/flushed.
However these numbers are really low, and really other than the one in my Ford Focus, a long time ago, I don't remember an AT failing ever.
Manual, needs clutch changes, some grind gears, and of course eventual fluid changes.
I'd say there's an equal amount of chance for something to go wrong, but the AT will be more expensive to fix.
86'd is offline   Reply With Quote
Old 04-25-2012, 05:44 PM   #8
Xdragonxb0i
Drives: ex500r
thank you that the answer i'm looking for. my friend have an 06 Jenna (at) failed him at 75k was a bit concern. it
Old 04-26-2012, 02:23 AM   #9
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
lol good one
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Based on the now-known $24,200 US price, the CDN cost Sport-Tech CANADA 34 03-31-2012 10:14 AM
FR-S based Sedan? tripjammer Scion FR-S / Toyota 86 GT86 General Forum 19 03-28-2012 03:06 PM
Price based on perspective randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 70 01-20-2012 04:33 PM
motor trend: next WRX based on ft86 f1ver BRZ First-Gen (2012+) — General Topics 54 08-18-2011 05:05 AM
