Old 12-14-2012, 06:49 PM   #1
PeterB
PeterB's Avatar
Drives: Subaru BRZ Limited WRB
BRZ versus FRS: which is a firmer ride
I have a non-technical question about BRZ versus FRS suspension. I am interested in some feedback on which of the two gives less bumpy ride on uneven surface. I know the difference is not large. I drove both, but on different roads, so it is really difficult to tell.
I have seen some reports that FRS is a more bumpy ride, but then there were some other conflicting messages.
I read that FRS has more oversteer versus understeer of BRZ. I also found this info about springs:
Front OE Spring Rate:
Subaru BRZ 27 N/mm (153 lbs/in)
Scion FR-S 23 N/mm (131 lbs/in)
Rear OE Spring Rate:
Subaru BRZ 34 N/mm (195 lbs/in)
Scion FR-S 37 N/mm (211 lbs/in)
So, apparently, BRZ is stiffer in front and softer in the rear, but I am not sure how this contributes to an overall feel of more or less bumpy ride.
I would appreciate any feedback.
PeterB is offline   Reply With Quote
Old 12-14-2012, 07:04 PM   #2
mashal
DADA
mashal's Avatar
Drives: 2013
This has been discussed several times before , there is no real answer. I personally found the brz to be less agile around corners compared to the frs.
But everyone will answer this differently
I-Tapatalk
mashal is offline   Reply With Quote
Old 12-14-2012, 07:13 PM   #3
PeterB
PeterB's Avatar
Thanks, Mashal, but I have not seen a lot of direct discussion of this. Again, I’m asking about smooth versus rough ride, especially on rough surface. You mentioned agility around corners, but that seems to be a different issue.
Old 12-14-2012, 07:13 PM   #4
Burrcold
Exactly as mashal said, there is no definite answer. I found the FR-S to be a little more unnerving around turns (the tail definitely wanted to pop out more). I did find the FR-S to be a little less bumpy though and a TAD more comfortable. I drove both on the same roads, fairly close in time to each other. There wasn't a big enough difference for me to really care one way or another though. Both felt great!
Old 12-14-2012, 07:20 PM   #5
wbradley
Sarcastic SOB
wbradley's Avatar
FR-S has softer front springs and firmer rear to enable a snappier tail when cornering hard. I think most people would find the BRZ a tad firmer but comfort should be the same.
Old 12-14-2012, 07:23 PM   #6
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
Comfort is also a large function of tires in which both cars have the same Michelins. If comfort is your top priority, this car is not for you. If comfort is mildly important, grab a set of Continental Extreme Contact DWs. Those tires are grippy and yet very comfortable as a daily driver.
n8dog11914 is offline   Reply With Quote
Old 12-14-2012, 07:36 PM   #7
PeterB
PeterB's Avatar
To clarify, comfort is not my priority. I know both cars are a bumpy ride. It is one of the factors that might become relevant in the long run of still loving the car after driving it for months or years.
n8dog11914, great point about the tires. Thanks.
Old 12-14-2012, 07:47 PM   #8
OrbitalEllipses
Drives: Attitude
I'd look at interior accouterments; you're stuck with those whereas changing the ride is just $$$.
Old 12-14-2012, 08:18 PM   #9
PeterB
PeterB's Avatar
Are you saying I could make changes to the suspension to make it a more comfortable ride? Do you know of anybody posting how to do this?
Would that annul the warranty?
Old 12-14-2012, 08:28 PM   #10
OrbitalEllipses
Drives: Attitude
I don't imagine many companies making softer springs, but if you prefer the interior of one over the other it's entirely possible to swap out the stock suspension from one to the other (cheap as well). Other options include custom coilover setup with softer damping and soft springs.
It would affect warranty claims on the suspension only; possibly components such as brakes if you reinstalled them incorrectly. The car caries the warranty no matter what (well, except salvage titles and stuff like that), but CLAIMS can be denied if there's proof.
Old 12-14-2012, 08:35 PM   #11
fatoni
ride quality is not so much about the spring rate but the damper quality. i think the big thing is that if that is the deciding factor, you should know that you can probably buy an frs and suspension for the price of a brz.
Old 12-14-2012, 08:52 PM   #12
OrbitalEllipses
Drives: Attitude
An improperly matched damper/spring set can be bouncy too. I've not driven an FR-S, but I wouldn't call my BRZ bumpy at all. I hit a bump/crack/pothole and I feel it, I don't feel the chassis sway up and down. It's a firm ride.
Old 12-14-2012, 09:02 PM   #13
fatoni
im not trying to say that the brz isnt properly damped. im just saying that if you have any questions, you can simply buy the solution and an frs for the price of the brz.
Old 12-14-2012, 09:28 PM   #14
OrbitalEllipses
Drives: Attitude
I wasn't saying you said it was bouncy!
The original BRZ I ordered (which I did not purchase) I would have paid less than someone who bought an FR-S at MSRP at the Toyota dealership around the corner so what you're saying is only kind of true. I'd never settle for the FR-S if I wanted leather/suede, seat heaters, push start, smart keyless, etc..
Bore of FR-S rims versus TC1? stocktc1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 08-05-2015 11:28 AM
My FRS baseline VERSUS Visconti e85/Perrin/Injen/Motiv setup TyperRspec789 Engine, Exhaust, Transmission 15 12-24-2012 08:10 PM
FR-S versus Chevy truck :( Cjm005 Scion FR-S / Toyota 86 GT86 General Forum 29 12-10-2012 12:35 AM
side skirts area is bumpy. normal? dnL Scion FR-S / Toyota 86 GT86 General Forum 13 09-13-2012 04:54 PM
Size Comparison: FR-S versus tC and GT-R CSSM FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 58 03-05-2012 10:28 PM
