Old 12-14-2012, 06:39 AM   #1
Panman
Panman's Avatar
Drives: 86 GTS
Changing Camera etc Settings. - BRZ Nav
Hi All,
I've done a couple of searches but not been able to find it.
Sort of mentioned here: http://www.ft86club.com/forums/showt...t=Camera+setup
Can anyone point me to the button sequence to get into the camera menu on the BRZ Nav unit (Which is the same as the GTS86 Unit in Australia).
Thanks,
Keith
Panman is offline   Reply With Quote
Old 12-14-2012, 10:15 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
http://www.ft86club.com/forums/showp...5&postcount=41
with the car in ACC just hold down all three buttons on the radio and it takes you into a settings mode. This mode has a bunch of settings in it and I did not mess with any of the others since they seem to be a bit more important than just camera lines. I would not recommend messing around with it too much.
If you look at that thread, a couple of posts later the OP says to get into the menu its actually press the audio button and THEN press the next two.
Seat settings? Burrcold Cosmetic Modification (Interior/Exterior/Lighting) 38 07-01-2013 01:56 PM
TRAC/VSC Settings for AutoX? mkiisupra Tracking / Autocross / HPDE / Drifting 6 12-07-2012 07:11 PM
Canadian BRZ Navi EQ settings? Burrcold CANADA 10 11-13-2012 10:49 PM
Settings for TCS and AT atledreier Scion FR-S / Toyota 86 GT86 General Forum 3 08-20-2012 09:36 AM
EQ settings chadz Electronics | Audio | NAV | Infotainment 2 07-15-2012 09:18 PM
