Old 12-01-2012, 05:15 AM   #1
gonzo
Drives: frs
Largest Amp Possible Under Seats
What are the dimensions under the frs seats? Trying to figure out the largest size I can fit without taking off the seat to find out myself
gonzo is offline   Reply With Quote
Old 12-01-2012, 09:19 AM   #2
2forme
I can't even fit my hand under the seats to check for stuff that falls down. I mounted my 5 channel amp under the trunk carpet panel.
Old 12-01-2012, 10:15 AM   #3
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
There's only about 1 inch of height without modifying (cutting) the carpet ...the height is the biggest problem with under the seat mounting.
rmjjensen is offline   Reply With Quote
Old 12-01-2012, 10:09 PM   #4
gonzo
Drives: frs
The amps I am considering are about 2 1/8 inches. I really want to put it there so I don't have to run as long of a power wire.
So, if I cut the carpet, would a 2.5 inch amp work? I have no problem cutting shit up under the seat... no one sees it anyways!
The jl 500/1 is:
Width (inches) 7-7/8
Height (inches) 2-1/8
Depth (inches) 7-11/16
Old 12-01-2012, 10:12 PM   #5
gonzo
Drives: frs
Also, the amp is going to be at 4 ohms with 250-300 watts rms and it's class D so it shouldn't overheat under the seat.
Old 12-01-2012, 10:13 PM   #6
gonzo
Drives: frs
Do you mean next to the spare tire? Or to the sides by the jack/tools?
I'll check next time I'm back there. Worse comes to worse, I'll run it to the back
Old 12-01-2012, 11:07 PM   #7
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Has anyone seen these amps? I was told they sound great and are powerful for their size.
http://www.crutchfield.com/S-cIYWsmY...-PBR300X4.html
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 12-03-2012, 01:11 AM   #8
gonzo
Drives: frs
You guys are tripping, there's so much room under the middle of my seats
I'm going to try and mount the amp there. I'll let u know what happens
Old 12-03-2012, 01:22 AM   #9
midnightfrolic
Drives: Scion FRS A/T raven
I am getting an all in one loaded sub box with amp built in from Kicker. Model 11pecvr12 from kicker. Check it out. May be worth your while.
midnightfrolic is offline   Reply With Quote
Old 12-03-2012, 06:40 AM   #10
-max-
Drives: Firestorm FRS
I fit a Alpine PDX-v9 under the passenger seat. 2" height. Had to cut out the foam under the carpet and raise the rear of the seat a bit.
-max- is offline   Reply With Quote
Old 12-03-2012, 01:07 PM   #11
2forme
Maybe you just have tiny hands LOL.
Old 12-03-2012, 05:02 PM   #12
gonzo
Drives: frs
Not tiny, but not OJ simpson xx-large lol.
There's about 3-4 inches of space, so a 2 inch amp will definitely fit. Any ideas of what can hold the amp in the foam under the seat? I'm thinking some kind of anchor like a drywall anchor.
Old 12-03-2012, 05:03 PM   #13
gonzo
Drives: frs
Did you mount it rightside up to the floor? How did you raise the rear of the seat?
Old 12-03-2012, 05:03 PM   #14
gonzo
Drives: frs
Kicker :/
I'm also not getting a large box. I have the JL 8" microsub, so an amp wouldn't fit on that.
ModBargains.com | Your Largest, #1 TSW Wheel Distributor - Inexpensive & Lightweight! ModBargains.com Wheels and Tires 85 07-28-2014 04:32 PM
WTT: My FRS seats for your BRZ Premium Seats Hanakuso Interior Parts (Incl. Lighting) 17 03-04-2013 01:37 PM
Toyota recalls 7.43 mil cars largest recall in 16 yrs speedy racer Other Vehicles & General Automotive Discussions 12 10-10-2012 05:26 PM
Enjuku Racing - FREE Cash Giveaway to the 3 Largest Orders Before Oct 1st, 2012 Enjuku Racing Announcements, Contests, Giveaways 1 10-02-2012 09:00 AM
