Old 11-26-2012, 08:27 PM   #1
nquillen
Drives: SWP BRZ
Question TPMS Sensors When Cold?
Does anyone else have issue with the TPMS when cold?
I rechecked the tire pressure and they are all at 38ish psi, but as long as it is cold the light stays on.
What pressure is the system supposed to alert you?
nquillen is offline   Reply With Quote
The Following User Says Thank You to nquillen For This Useful Post:
Mo707 (11-26-2012)
Old 11-26-2012, 08:34 PM   #2
Burrcold
Drives: Subaru BRZ Limited
Sounds like you have a bad sensor. If all of your wheels are reading the same PSI, you shouldn't get a light (especially if you are anywhere in the 30's PSI range).
Are you sure your tire gauge is working properly?
Old 11-26-2012, 08:44 PM   #3
nquillen
Drives: SWP BRZ
I'll try another gauge.
Would this be covered by warranty?
Old 11-26-2012, 08:49 PM   #4
Chinadian
Chinadian's Avatar
Drives: FRS Whiteout
I have the symbol that looks like this for tire pressure blink for about a minute then stays on when i turn my car on (..!..). I read the manual it says something like if you are using non-scion tires then it will turn on. It started when i changed over to winter tires. I wonder if this is normal???? similar to people with the TPMS light when they change to winter tires.
Does anyone else have this problem?
Chinadian is offline   Reply With Quote
Old 11-26-2012, 09:00 PM   #5
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I'm not sure, but I may have had a similar issue. I regularly check my tire pressures (usually when I fill-up since I use the gas station air compressor) and have had it at the recommended pressure (35 psi cold I believe). One morning, I actually had to park outside (had some junk in the garage, was too lazy to put them away) and it just so happens to be one of the colder nights. The next morning, my TPMS lights came on, but I figured that it was only because of the cold and that they would turn off as it warmed up. After a couple of days, they didn't turn off so I stopped by the gas station to check, got ~32 psi at all four tires, so I topped them back off to 35, but the TPMS sensors stayed on. It actually finally turned off the next morning. Not really sure what to make of that, haven't had to park outside nor have had cold nights, so
Old 11-26-2012, 09:03 PM   #6
Burrcold
If you put winter tires on, and didn't add your TPMS sensors then you will set off the light.
Old 11-26-2012, 09:07 PM   #7
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
This would also cause the light to always stay on and not turn off.
Flat Black VW is offline   Reply With Quote
Old 11-26-2012, 09:15 PM   #8
Burrcold
Not on short drives. It takes a longer trip to make the light come on.
Old 11-26-2012, 09:16 PM   #9
xjohnx
Grip>Slip
xjohnx's Avatar
Not the case. I don't have TPMS sensors in my wheels and i don't get the light until i've been driving 30-40 miles continually.
The Following User Says Thank You to xjohnx For This Useful Post:
Burrcold (11-26-2012)
Old 11-26-2012, 09:41 PM   #10
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Mine came on when the temps here dropped below freezing, but went off as soon as it got warmer (upper 40's/50's).
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 11-26-2012, 09:56 PM   #11
Flat Black VW
What I meant was once its on it would not go back off.
Old 11-26-2012, 09:58 PM   #12
Mo707
Mo707's Avatar
Yep happened to me. I let some air out and put more in. Then it want away. It was in the morning and probably one of the coldest days.
Mo707 is offline   Reply With Quote
Old 11-26-2012, 10:00 PM   #13
xjohnx
Grip>Slip
xjohnx's Avatar
Also not the case in my experience, mine seems to reset itself after being powered off for a couple hours (i.e., in the parking lot at work.)
Old 11-26-2012, 10:35 PM   #14
grgonium
grgonium's Avatar
Drives: Whiteout FR-S
Cold temps affect tire pressure, which causes the light to go on. Once temp warms up, light should go off.
grgonium is offline   Reply With Quote
TPMS Sensors kanundrum Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 249 06-21-2019 04:22 AM
TPMS Sensors.. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-08-2014 01:22 PM
TPMS Sensors ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 78 05-24-2013 04:24 PM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 08:25 AM
How to get rid of those Pesky TPMS Sensors! rL-gT Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 07-27-2012 08:53 PM
