Drives: 2013 Argento 6mt
Perrin drop in figment issue
Has anybody else had a problem installing the perrin drop in filter? It seems that the foam surround is too thick to close the air box all the way. When I clamp the top of the box back the bottom still has about an eighth inch gap and won't close all the way.
I Love custom Turbo kits
Drives: Limited BRZ
Make sure you are fitting the filter the right side.
I had some issues with the K&N filter because I didn't line up the filter properly. Move it around and see if it aligns.
Drives: SWP BRZ LTD
You are imagining things.
Same problem here
I just left it like that tho. cant make it fit right.
ScionFrsFan
Drives: Matte Black STI
It could be that the bottom of the box isn't clipped in all the way making it tough. We had a customer call about this a few weeks back, and we checked it with an air box we had sitting around, and it was fine. I even had one of our sales girls test it out to make sure it wasn't too hard to close and it was just fine. My guess is the filter is backwards, or it may not be centered in the air box properly.
Let us know if that helps and if not give us a ring Monday and lets figure it out! LATER! |
Drives: 2013 Scion Frs(Scarlet)
my hks gave me the same problem...u have to fight with a little and make sure it lines up right...if im not mistaken the fat part of filter is suppose to face you and you have to pay attention to the curves of the filter cuz theres one corner that is different from the other three
Drives: Whiteout FR-S
I had the same problem on my Cosworth filter, just have to keep at it you can get it closed.
We made the edge in a foam so it can have a nice seal, were the stock part has a strange lip formed in that paper like material. It makes the box seal nice and tight, but also can be a bit trickier to get it all lined up. Especially since the inlet hose holds it from opening too far. You can always unbolt the box from the car (just 3 bolts and a hose clamp) and do it that way.
the foam fits fine, obtain a symmetrical 2mm overlap around edge all way around then seal it up. works great.
#10 |
AIM4APX
Drives: 2013 WRB BRZ Limited
I had issues with my bottom lining up when I first installed and then it seemed like the top was off. You have to make sure the bottom is in snugly, then pull it tightly closed and snap the top latches.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
#11 |
DEEEERP
its normal, the fitment is tight and it has to be just right. my buddy's aFe drop in was the same thing.
| The Following User Says Thank You to JDMenrique For This Useful Post: | gmookher (11-10-2012) |
#12 |
Same here. Normal. Had to wrestle it a bit but got it to fit tightly sealed.
@dsomegax.cars
2013 Subaru BRZ Limited | WRB | STI tS Build Thread [SOLD] 2019 BMW M2 Competition | LBB | ///M Performance Build Thread 2020 Toyota GR Supra | Turbulence | TRD | Build Thread |
#13 |
Thanks guys, I went back and put a little more muscle into it and got it to line up correctly. I was just being too cautious trying not to break anything the first time.
#14 |
Ontario's FT86
Drives: 2016 Lexus GS-F
I just got my perrin drop in and i tried to installed it but was unable to close to air box tightly I just give up, will try again tomorrow during the day time..
| Who is going to buy the FRS DROP DROP Shop? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 10-18-2012 05:45 PM |
| Muffler Delete + Perrin Drop-in Filter | SkitterSkotter | Engine, Exhaust, Transmission | 20 | 10-10-2012 01:23 PM |
| Perrin drop in | mach330 | Engine, Exhaust, Transmission | 4 | 10-08-2012 06:01 PM |
| TRD Drop in AF | feldy | Engine, Exhaust, Transmission | 2 | 06-05-2012 08:40 PM |
