| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2013 FR-S Argento
factory differential fluid warning
for the past month or so I've noticed a slight catching/roughness/vibration in the rear end when turning from a stop so I decided to change out the diff fluid as a quick and easy thing to try to see if would make a difference.
When I drained the factory fluid only 1 liter came out. I believe the specs say it should have around 1.3 liters so it was definitely low. Sludge on the magnetic drain plug. Filled it up to the fill hole until it was just barely "weeping" out with 1.25 liters of Motul 300 LS 75w90 (LS stands for LImited Slip). The slight catching/roughness/vibration completely gone - nothing but smoothness now. So check your factory fluid fill levels and use quality fluids. It makes a difference. |
#2 |
I thought we were suppose to use the normal Motul 300. Not the LS?
#3 |
Drives: FR-S, Exige S, Miata
Thats what I thought since we don't need the FM.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield '95 Miata (Montego Blue) |
#4 |
You can use either regular Gear 300 or Gear 300 LS.
Our differentials do not need the LS additives, at the same time, having it will not do it any harm, just spending a bit extra for something that isn't needed. Adam |
#5 |
Site Moderator
Drives: Stuff
Great, mine's been doing that for awhile now.. thousands of miles.. DOH! Changing it this week if I can get some Motul in
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#6 |
Drives: Whiteout FR-S
No Limit should be able to get it to you quickly, i got mine in 2 days from NY to Arkansas. I'm hoping to change mine out this week i should have done it when i installed the cat back but i have to put the overpipe on this week too so it will be back on the lift.
#7 |
wheel gap
Drives: whiteout frs, 04 xrs
the motul 300 feels much better than the oe fluid
#8 | |
Site Moderator
Drives: Stuff
a lot easier than the torco mtf I ended up ordering through amazon.
-Dave
#9 |
Drives: 4Runner
I had the same issue as the OP. changed out the fluid to Lucas and the vibration/grind is gone. I didn't measure the amount of OEM fluid I drained but the drain plug definately had a lot of material on the maganet.
diirk
waiting on a Neptune Premium MT |
#10 |
The Mechanic
Drives: Civic Turbo,FR-S
Figured it would have a lot of shavings.Im planning to change all fluids at 1500 miles
#11 |
Site Moderator
Drives: Stuff
A lot of material on the magnet is pretty standard for new diffs. S2K had a ton, RX7s had a ton, etc.
-Dave
#12 | |
-Mike Paisan ![]() 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
#13 |
Well, i guess i know what i will be doing this week lol
FIVE AXIS DESIGN http://www.fivead.net (FIVE:AD Edition Ultramarine FR-S)
VTR http://vtrweb.com/ (Reccomended Pacific NW Shop!) [CLOSED] AVO Turbo http://www.avoturboworld.com (Great Products for a Great Price!) |
| What Differential fluid is in your BRZ/FRS? | ft86Fan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 11-12-2012 08:57 PM |
| Is the Limited slip differential identifiable? | jabbajaw99 | Engine, Exhaust, Transmission | 10 | 09-14-2012 07:23 AM |
| Get your Cusco Differential Cover from Kronos! | KronosPerformance | Transmission and Driveline | 5 | 07-04-2012 09:33 PM |
| Differential growl or ratcheting | Roadstercycle | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-17-2012 09:13 PM |
| Confirmed Torsen Differential | Andy | Engine, Exhaust, Transmission | 50 | 12-12-2011 11:01 PM |
